Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
326 Discussions
Acer predator helios 300 (2022 model) - abruptly shutting down
Satvik
Hi, I have an Acer Predator Helios 300 (2022 model) that is abruptly shutting down. I checked the status using the Performance and diagnostics monitor and the following error was reported.
[Cause: A device has reported a "Not OK" status.
Details: The device, Intel RST VMD Managed Controller 09AB, is reporting a bad status value. This device will not be available until the issue is resolved. The Plug and Play ID for this device is PCI\VEN_8086&DEV_09AB&SUBSYS_15981025&REV_00\3&11583659&0&30]
Could a representative from Intel support assist in resolving this issue? The laptop is not even a year old. Any recommendation or suggestion would be appreciated.
Anticipating the resolution of the documented error.
Satvik
Jocelyn_Intel
Hello, @Satvik
Thank you for posting on the Intel® communities. I will do the best I can to assist you here.
We are moving this thread to the Software Storage Technologies Forum as this is not related to Graphics.
Regarding your issue, do you have a RAID configuration or use Intel® Optane?
Jocelyn M.
Satvik
Hello @Jocelyn_Intel
Thank you for replying to my post. In my case, I have Intel Optane installed in my system.
Satvik
Jocelyn_Intel
Hello, @Satvik
Thank you for your reply and the information provided.
In that case, have you made sure that your RST driver is up to date with your System Manufacturer? This driver is also provided on the System Manufacturer's website
Jocelyn M.
Satvik
I have checked with the System Manufacturer's Website and found out that my RST driver is up to date.
Satvik
Jocelyn_Intel
Hello, @Satvik
Thank you for your confirmation on this.
Have you tried the generic driver 19.5.2.1049.5 already? Please let me know the results.
Jocelyn M.
Satvik
Hello @Jocelyn_Intel, as you suggested I installed the generic driver 19.5.2.1049.5 and scanned it again.  The following is the output:
Device is not working properly; Windows cannot load the required device drivers.
Cause: A device has a configuration problem that prevents it from working properly.
Details: The device, Intel(R) Iris(R) Xe Graphics, is reporting "tv_ConfigMgrErr31". This device will not be available until the issue is resolved. The Plug and Play ID for this device is ROOT\DISPLAY\0000.
Please advise.
Satvik
Jocelyn_Intel
Hello, @Satvik
Thank you for your reply.
In that case, roll back to your System Manufacturer's driver and contact them for further assistance as this issue seems hardware-related.
Although installing the drivers from your System Manufacturer is recommended, we wanted to try the generic driver since the previous one didn't work. We have tried everything until now, you need to contact your System Manufacturer for further assistance.
Jocelyn M.
Satvik
Hello @Jocelyn_Intel , thanks for your reply. I will contact the system manufacturer.
Satvik
Jocelyn_Intel
Hello, @Satvik
Sure, I am glad to help as best as I can anytime.
This thread will no longer be monitored, but if you need assistance with other matters, feel free to contact us back and submit a new post.
I hope you can solve this issue soon.
Jocelyn M.
salma98670
Hello, Satvik, hope "Not OK" status can be solved quickly.
1.Can you check with the System Manufacturer's Website and found out whether RST driver is up to date?
2.Did you get the after-sale service of Acer Predator Helios 300 from Acer's official website,Is it possible that it has a faulty about Acer CPU or Predator DRAM Storage? Is it possible to contact customer service online for help if restarting multiple times doesn't work.
