Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
BIOS not detecting disks after DiskPart wipe on Intel NUC
iNotChoco
Hello, I have an issue with boot and disk detection on my Intel NUC.
I used to have a triple boot with Windows, Kali, and Manjaro, but the GRUB bootloader got corrupted, so I decided to reinstall everything from scratch. For that, I used DiskPart to completely wipe the C: drive. Since then, the BIOS does not recognize either the primary or secondary disk and only detects network boots (PXE) over Ethernet.
On startup, the message shown is:
Checking Media Presence
Media present
Boot PXE over IPv4
[after a while...]
Boot PXE over IPv6
Eventually, Windows boots normally, but the BIOS seems not to recognize the disks properly.
I have checked BIOS settings, including boot mode (UEFI/Legacy), and verified disk health with CrystalDiskInfo (image attached), which shows good health.
Has anyone experienced a similar problem or knows how to get the BIOS to properly detect the disks?
Thanks in advance.
DeancR_Intel
Thank you for posting in the Community regarding the boot and disk detection issue you're experiencing with your Intel NUC. I understand how concerning it can be when your system doesn't recognize the disks properly, and I'm here to assist you in resolving this matter.
To help us diagnose the issue more effectively, could you please provide the following information:
  • Knowing the specific model of your Intel NUC will help us identify any compatibility issues or known problems that might be affecting your system.
  • Could you confirm the current BIOS version installed on your NUC? This information can help us determine if an update might be necessary.
  • Have you tried reconfiguring the disk settings in the BIOS, such as changing the boot order or ensuring the disks are set to AHCI mode?
  • Besides checking the BIOS settings and verifying disk health, have you tried any other troubleshooting steps to resolve the issue?
  • SSU log will give us detailed information about your system configuration and help us identify any potential issues. You can download the Intel System Support Utility (SSU) here. Please follow these instructions to generate and submit the SSU log:
    • Install and run the utility.
    • Click "Scan" to gather system information.
    • Once the scan is complete, click "Save" to export the results.
    • Attach the saved file in your response to this email.
  • Would you be interested in remote assistance to help resolve any remaining issues? If so, please let us know a convenient time for a phone call to further check and assist.
Your cooperation is greatly appreciated, and I look forward to assisting you further.
Dean R.
iNotChoco
Hi Dean,
Thanks a lot for your response.
Intel NUC model: NUC8i3BEH
BIOS version: Intel Corp. BECFL357.86A.0089.2021.0621.1343, 21/06/2021
I’ve checked the BIOS settings. The boot order is correct and the disk is set as the first boot device. The SATA mode is set to AHCI.
Before reinstalling Windows, I used DiskPart to clean the C: drive. Then I reinstalled Windows normally. The system boots, but the BIOS still shows PXE boot first and doesn’t list the internal drives. I also checked the disk health with CrystalDiskInfo and everything looks good (SMART values OK).
I’ve run the Intel SSU tool and attached the report as requested. Please let me know if anything stands out.
As for remote assistance, I prefer to continue through the forum.
Thanks again for your help!
n_scott_pearson
In the BIOS | BOOT Priority settings, is Boot Network Devices Last selected (checkmarked)? [It should be]
Also in the BIOS | BOOT Priority settings, is Network Boot set to Disabled? [It should be]
Hope this helps,
DeancR_Intel
Hi iNotChoco,
I wanted to follow up on the previous message and the post by n_scott_pearson regarding your inquiry. Have you had a chance to review it? If you have any questions or need further information, please let me know.
Dean R.
iNotChoco
Hi Dean, at the moment I have not had time to check it, this afternoon I will do it, as soon as I do I will send you comments. By the way, was the information I sent you useful?
Thanks in advance
DeancR_Intel
Hi iNotChoco,
Thank you for your detailed response and for providing the Intel NUC model and BIOS version. I appreciate your efforts in checking the BIOS settings and running the Intel SSU tool. Your thorough approach is invaluable in diagnosing the issue.
I understand the frustration of dealing with persistent boot issues, and I want to ensure you receive the support you need. Please be advised that the technical and warranty support for Intel’s NUC 7 through NUC 13 systems has transitioned to ASUS as of January 16, 2024. For further assistance, please contact Official Support | ASUS Global.
All software, firmware, BIOS support, and security advisories will be supported through ASUS as well. I sincerely apologize for not providing the expected answer you were seeking. I will be closing this thread as you reach out to ASUS for further assistance.
Thank you for your understanding and cooperation.
Dean R.
