Kgold1,
Intel® VROC does support third party SSDs, the limitation is related to the Intel(R) X299 chipset on the motherboard mentioned. If you were using a different board with a different chipset the usage of third party SSDs would be available, there is a list of tested SSDs on that type of solution.
This is the list, note this is not for your system but other boards that also support Intel(R) VROC:
https://www.intel.com/content/www/us/en/support/articles/000030310/memory-and-storage/ssd-software.html
Yes, you will be able to use the Intel(R) SSDs as boot drives with the setup mentioned, and the RAID levels supported would be 0/1/5/10 to boot from. (Windows 10* is the OS supported)
Esteban C
Hello Kgold1,
Thank you for contacting the Intel Communities.
Since the system has an Intel(R) x299 chipset the answer would be the following: No. Intel VROC on X299 platforms supports Intel® SSDs only.
You may reference to this article about Intel® VROC and the x299 chipset: https://www.intel.com/content/www/us/en/support/articles/000026106/memory-and-storage/ssd-software.html
Esteban C
Thank you for response. That really disappointing that Intel have so limited compatibility. Will Intel drives will be bootable on setup i mention before? will vroc standard key will work on intel drives to create bootable RAID-0?
Kgold1,
Esteban C
Topic Options
