I'm trying to install VROC 8.0.0.4035 on a Win Server 2019 Standard based on a 741er Chipset with Gen4 Xenon. The installation aborts with the message that the operating system is not supported.
At the moment I have no real idea where to look to correct the problem.
ps.: VROC 7.8 installed without problem.
Hi Sol5,
Thank you for posting on Intel Community.
Please allow us some time as we are reviewing the issue reported and we shall get back with an update at the earliest.
Megha K
Hi Sol5,
In continuation with the previous post, we request to please confirm the server details and the SSD model that is being used.
Megha K
Hi Sol5,
We request to please confirm the server details and the SSD model that is being used to assist you further with the query.
Megha K
Board is:
Hi Sol5,
Thank you for confirming the details.
We request to please follow the below link to check the supported configurations for Intel VROC.
Megha K
Again,
the requiremements for the chipset, the CPU and the Operating System check out to allow the install of V8. The error occures even when no drive is connected. The reported error is that the Operating System (Windows Server 2019 Standard) is not compatibel. Which it is supposed to be. So I assume that something during the install information gathering process must go wrong.
Regards, Lars
And the above Version of V8 is the only one, that is distributed by Supermicro with the mentioned board and the only one ditributed bei intel directly. Both show the exact same error.
Hi Sol5,
Please allow us some time to review the details shared and we shall get back with an update at the earliest.
Megha K
Hi Sol5,
Please find the below details for the issue reported.
Please note VROC 8.x installer is different from the VROC 7.x installer.
It's recommended to the check and make sure the requirements are met before installation.
The requirements are documented in the User Guide for Windows ( https://www.intel.com/content/www/us/en/support/articles/000094004/memory-and-storage/datacenter-storage-solutions.html ) – section 6.2.1.
Since this is a Supermicro platform, we request to check with OEM to make sure all the dependencies are addressed.
Also since, VROC is a platform dependent product, we request to check with OEM specially when upgrading the VROC version to a newer one (VROC 7.x to VROC 8.x).
Also, if you are still using a VROC Pre-OS version 7.x, you can continue using the VROC 7.x application.
Or alternatively, try to also upgrade the Pre-OS to VROC 8.x and for this, we request to check with OEM too.
Newer VROC versions are backwards compatible, but it's preferable to use the same versions in the pre-OS as well as in the OS.
Megha K
Would anyone please mind to at least once read and try to understanmd my text? Thank you!
The installer fails with the report that the operation system does not match the requirements - it fails with that specific error message.
As I'm installing on a Windows Server 2019 Standard this szenario should be supported. I attached the install log so someone with knowlege of the installer packaging might look into the problem, so that the error can be fixed in future installer versions - what ever the error might be.
The install of V8 allready failed as no V7.8 was installed.
Contacting Supermicro will not add anything, as they are only repackaging your installer. In the end this needs to be fixed on intels side.
Regards, Lars
Hi Sol5,
We are currently reviewing your question and we will provide you with a solution as soon as possible.
Megha K
Hi Sol5,
In order to assist you further with the issue reported, we request to please confirm the windows type that is being used. ( please confirm which "NTProductType" is being used )
One way to check this is the following:
Start the registry editor (regedt32.exe).
Move to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\ProductOptions.
Look at ProductType.
We await your response to assist you further.
Megha K
Hi Sol5,
Please note this is a follow up post requesting to help us with the details requested on the previous post.
Megha K
Hi Sol5,
Greetings for the day!
We have not received a reply from you , and as such, we will be closing your case.
If you want to continue support, please reply to this post and we will reopen your case or create a new one so that we can continue to support you.
Megha k
