Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
Intel Nuc BOXNUC7i7BNHX1
Satcanarias
Buenas tardes, tengo un equipo Intel Nuc BOXNUC7i7BNHX1 que cuando le desconecto la corriente de entrada durante más de 24 horas cuando lo enciendo aparece la fecha de cuando se desconectó la corriente.
¿Podría ser fallo de la pila? Lo raro es que la fecha la conserva pero congelada al momento en el que se le quito la corriente de entrada.
Otra cosa que le está pasando es que al conectarle la corriente la luz del frontal del Nuc se enciende la luz Roja y luego cambia a Azul, vuelve otra vez a Roja y luego se queda en Azul.
Saludos y muchas gracias anticipadas
LeonWaksman
I would try to replace the CMOS battery. Since this battery in your NUC is located on board upper site, the board need to be removed from its case.  This video will help you with this task.  You may buy a replacement battery in your local dealer or online (this is an example).   Before installing the new battery, verify that the wire polarity is the same as in the original battery.
Leon
Satcanarias
Ok, pediré la pila y desde que me llegue la sustituiré, muchas gracias por la respuesta.
Meghak
Hi Satcanarias,
Thank you for posting on Intel Community.
Please note all support for Intel NUC 7 - 13 systems has transitioned to ASUS.
Request to please check the below link : https://www.intel.com/content/www/us/en/support/articles/000097279/intel-nuc.html
Megha K
eleanoramber
It seems like your Intel NUC might have a CMOS battery issue causing the date to freeze. I recommend checking and replacing the CMOS battery. As for the LED behavior, consult the user manual for insights. If issues persist, contact Intel support.
AlHill
@eleanoramber   "If issues persist, contact Intel support."
Is that not what the OP did?  Of, do you need chatgpt to answer that for you?
