Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
P4800X steup
yoni
Hello.
I want to combine P4800X OPTANE SSD with IMDT to create the illusion of DRAM.
I am confused about the setup I need.
In this link: https://www.intel.com/content/www/us/en/products/docs/memory-storage/solid-state-drives/optane-ssd-dc-p4800x-mdt-brief.html
It's written I need "Xeon" processors for the IMDT and P4800X.
But in this document (in the last page of specifications): https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/intel-mdt-setup-guide.pdf
It's written it supports both "Xeon" and specific i7 modules.
Which is right? What setup I need for P4800X with IMDT?
Thank you very much.
BrusC_Intel
Hello, 3000023368131.5691580304164785E12.
Good day,
Thank you for contacting Intel Community Support.
The "Intel Memory Drive Technology Set Up and Integration guide" takes precedence since it continuously gets reviewed and updated (the latest being from August 2019), the document "product brief" is from last year.
You can follow the guide and if you have any questions or concerns, just let us know.
Bruce C.
A Contingent Worker at Intel
BrusC_Intel
Good day,
Bruce C.
yoni
Thanks for your replay. Just to be sure, the "Intel® Core™ i7-7800X X-series Processor" should be compatible with P4800X and IMDT?
BrusC_Intel
Yes, that is correct, that processor is compatible with that technology as seen in the "Intel Memory Drive Technology Set Up and Integration guide" you found.
Let me know in case you encounter any problems or if you require anything else.
Bruce C.
