Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
340 Discussions
Question about Intel Rapid-Storage 13.2.4.1000 for a Raid 5-System. Hot-Plug function can not be activated. Why?
WVoel
AlHill
Tell us more about your system.
Download, run, and save the results of this utility as a text file:
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility
Then ATTACH the text file (using the paperclip under the toolbar).
Doc
WVoel
Thanks for your fast reaction!
I have the text file, but do you mean " attach by paperclip under toolbar"?
Sorry, I don't know.
WVoel
AlHill
In your "REPLY" box, there is a toolbar. Under the toolbar is a paperclip. Use that to attach the text file.
Doc
WVoel
Here the wanted SSU file.
WVoel
Alberto_R_Intel
WVoel, Thank you for posting in the Intel® Communities Support.
I just wanted to check if the scenario of the Hot-Plug function not being activated on a RAID 5 configuration still persists and if you need further assistance on this matter?
Albert R.
A Contingent Worker at Intel
WVoel
Hi Albert!
Thanks for asking. The hotplug function is deactivated unchanged and cannot be activated. The Intel Rapid Storage software is an old version that otherwise runs without errors. Newer versions were apparently not compatible with the chipset. Yes, I need competent help.
Kind regards,
WVoel
Alberto_R_Intel
Hi WVoel, You are very welcome, thank you very much for your response.
Correct, as you mentioned, the reason why the Hot-Plug feature cannot be activated on your 5-RAID configuration platform is due to compatibility, the Intel® Rapid Storage Technology version 13.2.4.1000 does not support that option that was designed mainly for Server boards.
Additionally, the Intel® Core™2 Quad Processor Q9550 is also not compatible with Windows* 10 so basically, the reason why the Hot-Plug cannot be activated is due to compatibility between hardware and software being used.
Albert R.
WVoel
Hello Albert,
my PC is old and not fast, but extremely stable, reliable and completely sufficient for me. Windows 10 x64 does not cause the slightest problem either. Still my question about the last executable version of the Intel Rapid Storage for my PC. You are from the manufacturer of Intel Rapid Storage and definitely have reliable information.
Kind regards
Wolfgang
Alberto_R_Intel
WVoel, Thank you very much for letting us know those details.
In reference to your question about the last executable version of the Intel® Rapid Storage Technology for your PC, in order to gather that information the next thing to do will be to get in contact directly with the manufacturer of the computer, they will be able to provide the version of the Intel® Rapid Storage Technology that was validated by them for you to install it in your platform.
Albert R.
