Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
RSTについて
修野崎00
RSTを使用したいと思っていますが、インストールしようとすると
「このプラットフォームには対応してません」となってしまいます。
CPU Core i9 9900k
チップセット Z390
です。わかる方がいらっしゃいましたらご教授ください。
David_V_Intel
Hello 修野崎00, Thank you for posting on the Intel ® communities. Please keep in mind that the best Intel ® Rapid Storage Technology version for your system is always either the motherboard manufacturer's version provided or else the system manufacturer's provided (Dell, Lenovo, Asus, etc.). In order to best guide you I will need more system information, specifically I will need the motherboard model and the System Support Utility report, this report can be generated from our tool, you can refer to the link below so you can download it:  https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- Make sure to attach the created report to this thread. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
修野崎00
Thank you DavidV Because I do not understand English, I will reply by the translation function. I attach my system information. Windows 10 版のメール<https://go.microsoft.com/fwlink/?LinkId=550986>から送信
David_V_Intel
Hello 修野崎00, Thank you for your response. Please attach the system support utility report in the thread, there is an attach option on the lower part of the reply box. I was unable to access the one you provided so please attach it directly to this thread. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
修野崎00
Hello David V
I'm sorry.
Attach.
David_V_Intel
Hello 修野崎00, Thank you for your response. Please refer to the link below: https://www.asus.com/Motherboards/ROG-MAXIMUS-XI-FORMULA/HelpDesk_Download/ * Please be aware that the content on that site is not controlled by Intel*. This information is offered for your convenience and should not be viewed as an endorsement by Intel* for the merchants or services offered there. * There you can find the drivers & tools available for your motherboard, you can look under "SATA" and you will find the latest Intel ® Rapid Storage Technology version validated for your motherboard. I hope this helps. Regards, David V Intel Customer Support Technician Under Contract to Intel Corporation
修野崎00
Hello DavidV
I could install it.
Thank you very much.
