Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
Looking for RAID, VROC? You found the forum to ask questions!
351 Discussions
RSTe failure to install: 0x00004E24 This platform is not supported
Roland_W_Intel
My RAID(s) appear correctly in the Option ROM bootup, and behave correctly in Windows. I am having trouble installing the RSTe GUI.
Asus Prime X299-A motherboard BIOS version 1401
BIOS settings: RST is On. Intel RST Premium(RAID)
PCIe SSD for the boot drive (not part of the RAID)
4x4TB WD Red drives configured for RAID:
3 RAID Volumes:
ID 0 RAID 1 - uses disks on Ports 0 and 1
ID 1 RAID 0 - uses part of disks on Ports 3 and 5
ID 2 RAID 1 - uses part of disks on Ports 3 and 5
RST Option ROM 15.7.0.3054
Note, the RAID arrays were previously created on a different PC, an X99, and then ported over to this X299 system - the RAID functions correctly and all drives behave correctly. The issue is I can't install any RSTe GUI tools to monitor / manage / setup cache options etc.
Windows 10 Pro x64, Version 1803, latest build: 17134.137
I have tried installing the RSTe from both the Asus download site, and also the downloadcenter.intel.com site.
https://downloadcenter.intel.com/download/27331/VROC-and-RSTe-Driver-for-Windows- Download VROC and RSTe Driver for Windows*
With the Intel download I ran the RSTe_AHCI_VROC_NVMe_Win_5.3.0.1413_2017.10.30\GUI\RSTe_5.3.0.1413_Install\SetupRSTe.exe
I get the same error code with both installers:
0x00004E24 This Platform is not supported
Log files attached from:
C:\Users\rpwooste\AppData\Local\Temp\Intel\Logs
It looks like this person had the same problem, but I don't see a conclusion to the discussion.
Roland
VARADHARAJAN
Valued Contributor II
windows 10 pro or home or enterprise all are ciient operating system
More over , software link
above software supports only windows server 2016 64bit and windows server 2012 R2 64bit
Asus Prime X299-A motherboard BIOS version 1401 is client board , its not support windows server os
Moreover the checked the technical specifications of asus x299 prime boards , MB supports windows 10 client 64bit
you can download this
intel RST driver
http://dlcdnet.asus.com/pub/ASUS/mb/05SATA/IRST_Win7-10_V15711015_20170731.zip?_ga=2.131767951.1473421844.1531053122-1962244697.1531053122 http://dlcdnethttp://dlcdnet.asus.com/pub/ASUS/mb/05SATA/IRST_Win7-10_V15711015_20170731.zip?_ga=2.131767951.1473421844.1531053122-1962244697.1531053122 .asus.com/pub/ASUS/mb/05SATA/IRST_Win7-10_V15711015_20170731.zip?_ga=2.131767951.1473421844.1531053122-196
intel RST Virtual RAID on CPU (Intel® VROC) function
http://dlcdnet.asus.com/pub/ASUS/mb/05SATA/IRST_5.2.0.1194_20171130.zip?_ga=2.131767951.1473421844.1531053122-1962244697.1531053122 http://dlcdnet.asus.com/pub/ASUS/mb/05SATA/IRST_5.2.0.1194_20171130.zip?_ga=2.131767951.1473421844.1531053122-1962244697
restart the system
VARADHARAJAN
intel RST driver
restart the system
