Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
353 Discussions
VROC Raid on Server System R2208WFTZS
MKoeh
I have a new Intel Server System R2208WFTZS with 2 Xeon4114 CPU's and an installed VROCPEMMOD Raid Key (this is the key for 3rd parity SSD'S).
I have installed 2 Samsung PM863a Enterprise SSD drives and have connected the drives with the board with AXXCBL600CVCR (for each drive a cable).
So far so good. I flashed the newest BIOS on the System and the System runs.
But:
I can see the in the volume device Managemnt both SSD's
but in the UEFI Option ROM Control won't appear the
Intel® Virtual RAID on CPU
entry, so cannot build any raid with my SSD drives
What I have already done:
I have changed the VROCPEMMOD Raid Key
I bring System up with only one CPU installed
No effect - I cannot see the entry Intel Virtual RAID on CPU
Any suggestions / ideas?
Thank You
Martin
Carlos_V_Intel1
Hello Martin, Hope you are doing fine. Do you have other SSD to test the RAID creation? Charlie_V Intel Customer Support Technician Under Contract to Intel Corporation
MKoeh
Hello Carlos,
no I haven't other SSD's here to test the RAID creation. But I have the SSD temporary connected to the AHCI Controller on the board and at the AHCI Controller the work fine there.
Martin
Carlos_V_Intel1
Hello Martin, We noted that this case is duplicated from case 03975540 and is related to the same issue, so we are going to close it to continue in the mentioned case. You will receive an answer as soon as possible. Thank you for contacting Intel. Charlie_V Intel Customer Support Technician Under Contract to Intel Corporation
