Software Storage Technologies
Virtual RAID, RSTe, and Memory Drive Technology
353 Discussions
VROC, SAMSUNG PM961 RAID UNSUPPORTED
waltrox
Hi there!
I bought a Dell Precision 5820, compatible but not configured for RAID1 over VROC technology.
So I bought from third party
- Intel VROC Key Premium
- 2x Samsung PM961 (supported third pary vendor SSDs)
and I installed them on the workstation.
Entering Intel(R) VROC configuration on boot (version 6.2.0.1034) I see the SSDs but it's impossible to configure them on RAID1: clicking on the disk it says RAID unsupported.
What do I have to do please, I'm going crazy!
Thank you,
Walter
screenshotscreenshot
BrusC_Intel
Hello, @waltrox.
Thank you for contacting the Intel Community Support.
I received your ticket regarding Intel® VROC, I will be glad to assist you.
Based on your screenshot, I checked the motherboard's user manual and confirmed this system uses the X299 chipset, this means that only Intel® drives are supported for Intel® VROC configurations.
-User manual: https://topics-cdn.dell.com/pdf/precision-5820-workstation_owners-manual2_en-us.pdf
Please review the following document for additional information about Intel® VROC on X299 platforms:
- Intel® VROC support on X299 FAQ: https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/ssd-software/VROC_Support_on_X299_FAQ.pdf
Based on this document, please take into consideration the following:
Intel® VROC is targeted as an enterprise product, mainly for Servers and Workstations. Also, per the details found in the article “Intel® VROC Support on X299 FAQ”, Intel® VROC was enabled on X299 client platforms (see below). This initial decision was made at the time of launch in 2017. Since then, it has become apparent that Intel® RST (and not Intel® VROC) is the better product to support SSD RAID on X299 platforms, partly because of Intel® RST availability, broad SSD support and no need for an extra HW key. Intel® RST is free and it supports Intel® as well as NON-Intel® storage devices.
Intel® VROC will continue to have its HW Key licensing policies, which are more in line with enterprise product expectations. From the above explanation, we hope it’s clear that for X299 / client platforms, our customers do NOT require purchasing Intel® VROC key for RAID 0 (even with NON-Intel® drives). Please use Intel® RST instead of Intel® VROC for RAID 0 and other configurations.
It is also recommended to contact the system manufacturer as they may have other information about non-Intel SSD on X299 platforms or other supported configurations.
This being said, I will proceed to close the thread, but if you require further assistance, please do not hesitate on contacting us back.
Bruce C.
A Contingent Worker at Intel
Aaron33
You are offering SOFTWARE Raid. What we need is the HARDWARE Raid.
Why don't you support brands other than Intel SSD/Nvme?
Please solve our problem by updating the BIOS.
n_scott_pearson
VROC, like RST, offers a hybrid H/W-S/W solution. If you want H/W RAID, go purchase a H/W RAID card (Mr. Deep Pockets).
Why offer a feature that doesn't put additional money towards Intel's bottom line? Humor aside, I believe the capabilities of the NVMe card make a difference.
Intel doesn't provide the BIOS, the board vendor does. I am unsure it's that simple, however.
Aaron33
Dell Precision 5820 | 7820 | 7920 Tower platforms has an internal raid controller(MegaRaid).
Unfortunately Software Raid performance is lower than that of Hardware Raid.
Also, software raid not bootable so the OS cannot be installed.
n_scott_pearson
Not true; Intel RAID is bootable and the O/S *can* be installed (you just have to insert the drivers into the image or load them during the install).
Aaron33
I insert the drivers(iaVROC.sys) and Windows 10 loading on Nvme RAID. But Windows doesn't open after installation. Because Software Raid => " Intel Virtual Raid On CPU Program - (Intel(R) VROC (in pass-thru mode)" not bootable.
I think it needs a Intel VROC Premium Hardware Key to boot.
VROCPREMMOD is very expensive and it's not sold anywhere.
http://www.xtremesystems.org/forums/showthread.php?296890-Sabrent-Rocket-12GB-s-VROC&fbclid=IwAR21rm0EXNIs5De-5hYwxSZXwZ5wrIhMEUnXrSSU_a4h-BVR2stMtZsmCRw
Bu
Aaron33
Intel Virtual RAID on CPU. (software raid)
