Hello
My configuration:
Fresh install of Server 2012 R2 on Mainboard Intel S1200SP (Chipset intel c600 /c220)
System installed on RAID 1 (two new SSD Samsung pro)
RAID (Chipset intel c600 /c220) driver version 4.6.0.1048
I have the issues, that the windows server backup fails with the error message "the drive cannot find the sector requested"
I tried chkdsk but found no error
So I searched further and one solution was to shrink the volume but I am not able to shrink the volume because it stops wirh the error message
"the drive cannot find the sector requested" 0x8007001B"
In the intel rapid storage UI seems everything normal but the volume is not initialyzed.
Do you have any hints what to do?
Thank you for any help!
Michael
Hello Siltalai,
Thank you for contacting the Intel® Rapid Storage Technology Enterprise support
We have checked all the information that you have provided us and it does't seem that the issue is not related to the Intel® RSTe software itself; however. Have you tried initializing the drive since If the volume is not initialized, the RAID initialization will happen in the background, but this can cause performance impacts as well as add a risk of data loss should a drive fail before background initialization completes.
Additionally we have research on the error message you provided us and we found relevant information on the following community post:
Please bear in mind that the external links here are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
https://serverfault.com/questions/832459/windows-server-2012-backup-the-drive-cannot-find-the-sector-requested https://serverfault.com/questions/832459/windows-server-2012-backup-the-drive-cannot-find-the-sector-requested
Best Regards
Luis H
Hello Siltalai,
We are following up on your community post since a few days ago we provided you with answers to your questions.
We are still awaiting for your reply, so please let us know if you require further assistance or if we can proceed to set the case status as resolved.
Best Regards
Luis H
Hello Luis,
sorry for the delay- I am still investigating..
Since its a production server I only have time at the weekends.
Best regards
Hello Siltalai,
We hope you are doing well
Thank you for getting back to us with the status of your issue.Please don't hesitate to contact us back if you have any question or update about the issue you are experiencing
Best Regards
Luis H
