Counting native events
Vincent_B_1
I try to count some performance events of a part of an application written in C.
So far, I have used PAPI to count events. It works fine for preset events. However, when I profile native events, all of them turn out to be translated into the same Event Code : 0x40000022 (an output of papi_avail is below). It makes no sense, but no error occurs when I profile them. What could be wrong ? How could I debug this ?
Also, I've got a list (from the perfmon directory) of events that can be counted for the architecture I work with (Ivy bridge) and the adresses and values of the associated registers. Is there an alternative to PAPI I could use to count a particular event of that list, over a certain part of the program, knowing the name of the event and the registers informations ? Would it work to simply write and read to the corresponding registers manually (for example using pcm-msr) ?
Thanks in advance for your help,
Vincent
$ papi_avail -e LLC_MISSES
Available events and hardware information.
PAPI Version             : 5.3.0.0
Vendor string and code   : GenuineIntel (1)
Model string and code    : Intel(R) Xeon(R) CPU E5-4610 v2 @ 2.30GHz (62)
CPU Revision             : 4.000000
CPUID Info               : Family: 6  Model: 62  Stepping: 4
CPU Max Megahertz        : 2294
CPU Min Megahertz        : 2294
Hdw Threads per core     : 1
Cores per Socket         : 8
Sockets                  : 4
NUMA Nodes               : 4
CPUs per Node            : 8
Total CPUs               : 32
Running in a VM          : no
Number Hardware Counters : 11
Max Multiplex Counters   : 64
Event name:                   LLC_MISSES
Event Code:                   0x40000022
Number of Register Values:    0
Description:                 |Alias for LAST_LEVEL_CACHE_MISSES|
Unit Masks:
 Mask Info:                  |:e=0|edge level (may require counter-mask >= 1)|
 Mask Info:                  |:i=0|invert|
 Mask Info:                  |:c=0|counter-mask in range [0-255]|
 Mask Info:                  |:t=0|measure any thread|
 Mask Info:                  |:u=0|monitor at user level|
 Mask Info:                  |:k=0|monitor at kernel level|
avail.c                                     PASSED
Thomas_W_Intel
Vincent,
Unfortunately, I'm can't help you with PAPI but you might want to have a look at Intel Performance Counter Monitor. It can be used to count L3 misses on some systems.
Kind regards
Thomas
