- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
hey, would it be possible to get a working driver for crimson desert for intel uhd? this is the error im getting. i just wanna know if its fixable with a driver or is it just the device itself
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
What is your processor model number?
[CoPilot is a virus, W11 is a keystroke logger, all from MicroSlop]
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
The latest driver for your 11th gen processor can be found here:
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
would it fix the error? because im pretty sure thats the driver i already have
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
If that is the driver you already have, then the problem is elsewhere.
Check you driver version in the device manager.
Also, check the game manufacturer for their requirements.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
It is the driver that I have, and also when i launch the game it recommends me to update to intel arc's 32.0.101.8626 driver which i can't use.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Do you not have ARC? what does the device manager say?
ALso, here is the latest driver for ARC:
https://www.intel.com/content/www/us/en/download/785597/intel-arc-graphics-windows.html
So we can end the confusion, does your game require ARC. This is where checking the requirements by the game manufacturer is important.
So the Intel customer support technicians can have more information about your system, download and run the Intel System Support Utility (https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- ) for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
wdym i don't have ARC? i said i have intel uhd graphics, oh and did you mean "your game does require ARC"?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Do what I said:
What are the manufacturer's requirements?
And,
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I mean if we're talking performance wise i do believe i might be able to run this game if thats what you mean by the manufacturer's requirements.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Ok, this should be simple. What are the hardware requirements for your game? Forget performance, just check with the game manufacturer for what hardware that is required. I suspect the game needs amd or nvidia graphics. It is up to you to make sure you have what the game needs.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
oh okay, you are kind of right they don't support my gpu yet but they do support intel after the latest patch. Thank You
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Yeah, I should have done more checking on a game and card that I do not have.
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
