Data Prefetching using Fortran Directives
Sina_M_
Hi every one,
I am working on sparse algorithms' optimization using Intel's Fortran compiler. After applying different optimization features I want to make suitable use of data prefetching and cache utilization. In order to do that I tested several probable configurations of prefetching directives and intrinsic functions on both Intel Corei7 and AMD APU processors. But I don't get expected results. But in a specific case I think I get a real prefetching which gives me a 3-4 times speed up.
Following is the faster code:
[fortran]
    DOUBLE PRECISION, DIMENSION(:), ALLOCATABLE :: A2D, X, TEMP
    DOUBLE PRECISION :: SUM
    INTEGER :: SIZE, I, J, COUNT, BLS, I0
    SIZE = 1000000
    BLS = 21 * 25
    ALLOCATE(A2D(0:BLS * SIZE - 1))
    ALLOCATE(X(0:SIZE - 1))
    ALLOCATE(TEMP(0:BLS - 1))
    DO COUNT = 0, 50
        !$OMP PARALLEL SHARED(A2D, X, SIZE, BLS)
        !$OMP DO SCHEDULE(STATIC) PRIVATE(J, I, SUM, TEMP, I0)
        !DEC$ SIMD
        DO J = 0, SIZE - 1
            I0 = BLS * J
            DO I = 0, BLS - 1
                TEMP(I) = A2D(I0 + I)
            END DO
            SUM = 0.D0
            DO I = 0, BLS - 1
                SUM = SUM + TEMP(I) * 2.D0
            END DO
            X(J) = SUM
        END DO
        !$OMP END DO
        !$OMP END PARALLEL
    END DO
[/fortran]
And the following is the code I expect to be correct but is around 4 times slower (I think because the prefetch directive does not work):
[fortran]
    SIZE = 1000000
    BLS = 21 * 25
    DO COUNT = 0, 50
        !DEC$ PREFETCH A2D
        DO J = 0, SIZE - 1
            I0 = BLS * J
            SUM = 0.D0
            !DEC$ SIMD
            DO I = 0, BLS - 1
                SUM = SUM + A2D(I0 + I) * 2.D0
            END DO
            X(J) = SUM
        END DO
        !$OMP END DO
        !$OMP END PARALLEL
    END DO
[/fortran]
I am really confused and need your help.
