Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
Error building Intel Performance Counter Monitor kext on OSX 10.9
Jorge_G_
Hello. I have a problem building the pcm kext. I am using OSX 10.9.
In file included from /PCM2.7_PATH/MacMSRDriver/PcmMsr/PcmMsrClient.cpp:15:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.9.sdk/System/Library/Frameworks/Kernel.framework/Headers/IOKit/IOLib.h:327:6: error:
conflicting types for 'Debugger'
void Debugger(const char * reason);
I´ll appreciate your help.
Jorge
Patrick_K_Intel
You can try removing /usr/include from the "Header Search Path" in Xcode. If you're building on OX 10.9 you'll likely also want to change the SDK to 10.9.
Jorge_G_
It works. Thanks.
