Software Tuning, Performance Optimization & Platform Monitoring
Discussion regarding monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform updating.
Measuring memory bandwidth through IntelPerformanceCounterMonitorV2.8
Jeongseob_A_
Hi all,
Currently, I have tried to measure the memory bandwidth per core. Fortunately, I saw the article (https://software.intel.com/en-us/articles/monitoring-integrated-memory-controller-requests-in-the-2nd-3rd-and-4th-generation-intel). So, I tested measuring memory bandwidth by using pcm-memory.x in my Linux system(Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz). However, the program produces the error like below.
Detected Intel(R) Core(TM) i5-4430 CPU @ 3.00GHz "Intel(r) microarchitecture codename Haswell"
Jaketown, Ivytown or Haswell Server CPU is required for this tool!
For processor-level memory bandwidth statistics please use pcm.x
I also tried to use pcm.x, but the READ and WRITE field do not show any data. It just prints N/A. Could you help me solve this problem?
Thomas_W_Intel
Intel PCM measures the memory bandwidth directly in the memory controller. It is therefore unfortunately not possible to tie this information back to the core. in particular, pcm-memory won't provide you this information either. The main advantage of pcm-memory is that it reports the memory traffic per memory channel.
Jeongseob_A_
Thank you for the reply.
 Core (SKT) | EXEC | IPC  | FREQ  | AFREQ | L3MISS | L2MISS | L3HIT | L2HIT | L3CLK | L2CLK |  READ | WRITE |  IO   | TEMP |
   0    0     0.01   0.67   0.01    0.31      78 K    202 K    0.61    0.26    0.32    0.11     N/A     N/A     N/A     68
   1    0     0.03   1.35   0.02    0.37     103 K    222 K    0.53    0.35    0.33    0.08     N/A     N/A     N/A     72
   2    0     0.00   0.33   0.01    0.33      48 K    135 K    0.64    0.22    0.38    0.16     N/A     N/A     N/A     71
   3    0     0.01   0.48   0.01    0.35     126 K    246 K    0.49    0.22    0.65    0.14     N/A     N/A     N/A     69
 SKT    0     0.01   0.82   0.01    0.34     357 K    807 K    0.56    0.27    0.41    0.11    0.89    0.08    0.79     67
When I run the pcm.x program, there are read and write fields per core like above. So, I just considered the information will be provided. Anyway, thanks very much.
