Software Tuning, Performance Optimization & Platform Monitoring
Discussion around monitoring and software tuning methodologies, Performance Monitoring Unit (PMU) of Intel microprocessors, and platform monitoring
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Power Capping by Power Governor and Power Gadget on Linux
Kevin
Hi everyone,
When I tried to use Power Governor(https://software.intel.com/en-us/articles/intel-power-governor) and Power Gadget(https://software.intel.com/en-us/articles/intel-power-gadget-20) to get the power consumption info of CPU, I got the following error:
RAPL not supported, or machine model 306f2 not recognized.
Init failed!
When I followed the README.md to "modprobe msr" and "modprobe cpuid", it shows:
FATAL: Module mrs not found.
FATAL: Module cpuid not found.
I found any posts in the forum but didn't find any problems like this.
The Purpose is to get the power consumption/temp info in a program.
Does anyone have any ideas how to deal with the problems above of these two tools or other methods to get the power consumption in a program?
Best wishes,
Jiawen
Carlos_P_
With that details, I believe your "DisplayFamily_DisplayModel" is 06_3FH.
Well, just checked on the Intel® 64 and IA-32 Architectures Software Developer’s Manual Documentation by that ID and I find RAPL registers available...
Try running this sample code: http://web.eece.maine.edu/~vweaver/projects/rapl/ (Userspace Access without perf)
Kevin
Hi everyone,
Does anyone know how to figure out this problem? I appreciate if anyone could give me any suggestions or ideas.
Jiawen
Carlos_P_
What's your CPU model?
Kevin
Hi Carlos,
The CPU is  Eighteen-Core/36-Threads Intel® Xeon® E5-2699 v3 2.3GHz-45MB Shared L3 Cache-9.6GT/s QPI-145W-22nm. Does it support the rapl architecture?
Carlos_P_
Kevin
Hi Carlos,
When I compile the code, I still get the error message as below:
[liu@fornax ~]$ gcc rapl-read.c
/tmp/ccKurDYv.o: In function `rapl_msr':
rapl-read.c:(.text+0x3f6): undefined reference to `pow'
rapl-read.c:(.text+0x43b): undefined reference to `pow'
rapl-read.c:(.text+0x480): undefined reference to `pow'
collect2: error: ld returned 1 exit status
Do you know what is the reason?
Jiawen
Carlos_P_
Hey,
you need to compile with the flag -lm
regards
Kevin
Hi Carlos,
After I run it, I got the following info showing that No perf_event rapl support found. I still didn't get the power consumption of CPUs. Do you know what's the problem?
[liu@fornax ~]$ sudo ./a.out
No perf_event rapl support found (requires Linux 3.14)
Falling back to raw msr support
Found Haswell-EP CPU
Checking core #0
Power units = 0.125W
CPU Energy units = 0.00006104J
DRAM Energy units = 0.00001526J
Time units = 0.00097656s
Package thermal spec: 145.000W
Package minimum power: 69.000W
Package maximum power: 290.000W
Package maximum time window: 0.045898s
Package power limits are unlocked
Package power limit #1: 145.000W for 0.009766s (enabled, clamped)
Package power limit #2: 174.000W for 0.002930s (enabled, clamped)
Package energy before: 75131.813354J
PowerPlane0 (core) for core 0 energy before: 0.000000J
rdmsr:pread: Input/output error
Jiawen
Carlos_P_
Hi Jiawen,
https://software.intel.com/pt-br/forums/software-tuning-performance-optimization-platform-monitoring...
Check that topic best reply from Patrick. Maybe you have a similar problem so, there are some MSR's that are not compatible with your processor, maybe they are the same since it is a E5 too.
Check if it will help you!
Try it and give some feedback :)
Regards!
Koji_T_
Hi all,
I'm having the same problem. The CPU is Xeon(R) CPU E5-2680 v3. Isn't there a way to make it work?
