RAPL & PCM
Huazhe_Z_
Hi guys,
I have been using RAPL for a while. However, I did not figure out how to disable RAPL accessing PMU in order to use PCM. Could anyone give me some idea on that? Thanks!
Roman_D_Intel
do you want to use just RAPL and no PMU in PCM?
Roman
Huazhe_Z_
Hi Roman,
First, thank you for fast reply.
I want to use RAPL(used to control power) and PCM(used to monitor some hardware info) seperately. That is I need to turn on and off the RAPL from time to time. To disable RAPL(the power capping function), I don''t know if it is equivalent to set a high power cap that the system could never reach. I also tried the enable bit introduced in MSR, but for some reason, it doesn't seem to disable the capping.
Huazhe
Roman_D_Intel
Huazhe,
Intel PCM does not use power capping/controlling functions. It only reads energy consumption information from RAPL registers (just monitors them).
Did you try Intel Power Governor to setup power capping?
Roman
