Good day -
I am trying to understand which tables in the SDM:
"Intel 64 and IA32 Architectures Software Developer's Manual, Combined Volumes 1 ... 2 ... 3 & 4" :
@ : https://software.intel.com/sites/default/files/managed/39/c5/325462-sdm-vol-1-2abcd-3abcd.pdf
apply to processors with CPUID DisplayFamily_DisplayModel 06_3CH , but am not assisted by
any text in the SDM.
There is considerable ambiguity in the Chapter 19 text about which Performance Event
tables apply to which processors - for example, for table 19.3:
" Table 19-3. Performance Events of the Processor Core Supported in Intel® Xeon® Processor Scalable Family with Skylake
Microarchitectures
There is no text in the SDM about which processor Display_Family:Display_Model(s) this table applies to -
in the preamble to the table on page 3451 it only states:
" The events in Table 19-4 apply to processors with CPUID signature of DisplayFamily_DisplayModel encoding
with the following value: 06_55H .
Is this a typo ? ie. is this text meant to refer to "Table 19-3", not "Table 19-4" ?
I am led to believe that it is, by the text on page 3471:
" Table 19-4. The events in Table 19-4 apply to processors with CPUID signature of DisplayFamily_DisplayModel encoding
with the following values: 06_4EH and 06_5EH. ... The events in Table 19-4 apply to processors with CPUID signature of
DisplayFamily_DisplayModel encoding with the following values: 06_8EH and 06_9EH.
Table 19-4. Performance Events of the Processor Core Supported by Skylake Microarchitecture and Kaby Lake Microarchitecture
no mention of 06_55H CPUs here - so it is a typo and "Table 19-3" is only for 06_55H CPUs ? Or not ?
I can find no text in the SDM that explicitly states which CPU DisplayFamily_DisplayModel pairs
Table 19-3 applies to - I think this is a major omission.
There only one mention in the text about which performance event tables CPUs with DisplayFamily_DisplayModel == 06_3CH
support , on page 3504:
" Processors with CPUID signature of DisplayFamily_DisplayModel 06_3CH and 06_45H support performance events listed in
Table 19-11.
I assume 06_3CH CPUs are Haswell, so only these tables should apply:
" Table 19-9. Performance Events in the Processor Core of 4th Generation Intel® Core™ Processors
Table 19-10. Intel TSX Performance Events in Processors Based on Haswell Microarchitecture
Table 19-11. Uncore Performance Events in the 4th Generation Intel® Core™ Processors
Yet one processor I'm testing with, an i7-4770, which has CPUID DisplayFamily_DisplayModel == 06_3CH (Haswell) seems to
support these events which are ONLY listed in Table 19-3, (Skylake) :
Event | Umask | Mnemonic
00H 01H INST_RETIRED.ANY
00H 02H CPU_CLK_UNHALTED.THREAD
00H 03H CPU_CLK_UNHALTED.REF_TSC
Indeed, linux maps the '/sys/bus/event_source/devices/cpu/events/ref-cycles' event to
the last one shown above.
So am I to assume that all events in Table 19-3 also are supported on this CPU ,
since it supports the first three ?
There are many duplicates and differences between Table 19-3 and Table 19-9 -
which events in which table are supported by 06_3CH CPUs ?
The manual does not offer much help in determining this.
It would be most helpful in future if Intel could include a definitive mapping between
CPUID DisplayFamily_DisplayModel values and supported Performance Event
table identifiers in the next edition of the SDM .
In the absence of this , could anyone please suggest a source of information about
precisely which events are meant to be supported by the 06_3CH CPUs ?
Are they Skylake or Haswell ?
Thanks in advance for any help / replies , Best Regards,
Jason <jason.vas.dias@gmail.com>
preceded by text on page
Or, in short :
I can't understand why my Haswell CPU with CPUID DisplayFamily_DisplayModel 06_3CH
( whose PMU events should be documented in Tables 19-9 , 19-10, 19-11 ? )
supports the Skylake Table 19-3 Event:
Event # | Umask # | Mnemonic
This event is documented nowhere else but in the Skylake Table. Is my "i7-4770" CPU some kind of
Haswell + Skylake hybrid ?
It silently accepts registration for Skylake events:
but always returns '0' for them.
$ egrep 'cpu family|model|name' /proc/cpuinfo | head -n 3
cpu family : 6
model : 60
model name : Intel(R) Core(TM) i7-4770 CPU @ 3.40GHz
$ perf stat -e r0300 sleep 1
Performance counter stats for 'sleep 1':
1,813,186 r0300
1.000883663 seconds time elapsed
So this event documented ONLY in Skylake table is supported on Haswell . Why ?
Is there a better source of mappings between CPUID DisplayFamily_DisplayModel and precise PMU events supported?
Those events are the "fixed-function" counters, which are normally accessed either using the RDMSR instruction (as described in Table 19-2 of Volume 3 of the Intel Architectures Software Developers Manual) OR by using the RDPMC instruction with special counter values of (1<<30+0), (1<<30+1), and (1<<30+2). This latter approach is described in the entry for the RDPMC instruction in Volume 2 of the Intel Architectures Software Developer's Manual.
I admit that I am a bit puzzled by the wording in Table 19-3. While it is clear that the fixed-function events described above are independent of the programmable counters, Table 19-3 suggests using a programmable counter for the same events -- which clearly cannot leave all of the other programmable counters available. I suggest ignoring the Event 0x00 encoding of the first three entries in Table 19-3 and use the special performance counter number encoding described above (i.e., counter numbers 1<<30 to 1<<30+2). If you want to use the programmable counters for these events, use the encodings from Table 19-1, which provides the same event coverage. For the fixed-function counters, the AnyThread bits are in the IA32_FIXED_CTR_CTRL MSR, instead of in the IA32_PERFEVTSEL* MSRs.
Note that the "reference cycles not halted" event means something slightly different in the fixed-function and programmable events. The programmable event increments once for each "tick" of the reference clock (while the processor is not halted), but the fixed-function counter increments by P for each "tick" of the reference clock (while the processors is not halted), where "P" is the same multiplier ratio used by the TSC.
