any one can help for this thread?
https://communities.intel.com/thread/125351
about J1900 SMI_LOCK SMI_EN
to get a good realtime performance, i want to disablle SMI on my J1900 MasterBoard, i edit the linux kernel, add some line in file [arch/x86/platform/atom/pmc_atom.c]:
here is what i have done:
1.clear SMI_EN.GBL_SMI_EN
2.set GEN_PMCON2.SMI_LOCK (yes,this bit before i set, it'vaule is zero--which mean BIOS doesn't LOCK SMI)
when the kernel running, use "sudo rdmsr --all 0x34" to check MSR_SMI_COUNT, but MSR_SMI_COUNT increased when time elapsed,WHY?
--1.two functions added in [arch/x86/platform/atom/pmc_atom.c]
static void clr_smi_en(void)
u16 reg_port;
u32 reg_value;
pr_info("DNK_clr_smi_en\n");
reg_port = acpi_base_addr + 0x30;
reg_value = inl(reg_port);
printk("DNK_A: SMI_EN:\t0x%08x\n", reg_value);
reg_port = acpi_base_addr + 0x34;
printk("SMI_STS:\t0x%08x\n", reg_value);
outl(0, reg_port);
printk("DNK_B: SMI_EN:\t0x%08x\n", reg_value);
static void pmc_smi_lock(struct pmc_dev *pmc)
u32 gen_pmcon2;
gen_pmcon2 = pmc_reg_read(pmc, 0x24);
printk("DNK_A: GEN_PMCON2=0x%08x", gen_pmcon2);
gen_pmcon2 |= 0x00000010;
printk("DNK_C: GEN_PMCON2=0x%08x", gen_pmcon2);
pmc_reg_write(pmc, 0x24, gen_pmcon2);
printk("DNK_B: GEN_PMCON2=0x%08x", gen_pmcon2);
--2.call these functions in function pmc_setup_dev which called by pmc_atom_init .
clr_smi_en();
pmc_smi_lock(pmc);
--3.dmesg log:
dnk@dnk-baytrail:~$ dmesg | grep DNK
[ 3.548661] DNK:pmc_atom_init
[ 3.548765] pmc_atom: DNK_clr_smi_en
[ 3.548786] DNK_A: SMI_EN: 0x00000033
[ 3.548831] DNK_B: SMI_EN: 0x00000002
[ 3.548851] DNK_A: GEN_PMCON2=0x00040400
[ 3.548870] DNK_C: GEN_PMCON2=0x00040410
[ 3.548892] DNK_B: GEN_PMCON2=0x00040410
Register Reference:
<Intel ® Pentium ® Processor N3500-series, J2850, J2900, and Intel ®Celeron ® Processor N2900-series,N2800-series, J1800-series, J1900,J1750>
Document Number: 329670-004
p997 20.5.6 General PM Configuration 2 (GEN_PMCON2)—Offset 24h
bit4
SMI Lock (SMI_LOCK) (smi_lock): When this bit is set, writes to the GBL_SMI_EN
bit will have no effect. Once the SMI_LOCK bit is set, writes of 0 to SMI_LOCK bit will
have no effect (i.e. once set, this bit can only be cleared by PMU_PLTRST).
p1035 20.7.6 SMI_EN - SMI Control and Enable (SMI_EN)—Offset 30h
bit0
Global SMI Enable (GBL_SMI_EN): (gbl_smi_en): When set, this bit enables the
generation of SMIs in the system upon any enabled SMI event. This bit is reset by a
PMU_PLTRST_B reset event. If this bit is not set, no SMI# will be generated. NOTE:
When the SMI_LOCK bit is set, this bit cannot be changed.
<Intel ® 64 and IA-32 Architectures Software Developer’s Manual>
Document Number: 252046-052
p980
Table 35-18. MSRs Supported by Intel® Processors based on Intel® microarchitecture code name Sandy Bridge
0x34 MSR_SMI_COUNT
this model specific register (MSR), returning the count of SMI since boot.
