vtune can not get the call stack
Wang_Ruifeng
HI, all.        I use vtune to help men get the applicatin call stack, but have some problem.
     if i do not add the static before the functions, the vtune can't get the call stack of the functions.for example:
if i do not add the static,the vtune will only get two funtion:testa,testb
if add the static,the vtune will get the call stack.  so my question is why the vtune can't get the call stack and the words 'static'  effect it?
my computer configuration:
 CPU:Intel E5504 2.0G
 OS: Suse 11 Sp1
GGCC: (SUSE Linux) 4.3.4 [gcc-4_3-branch revision 152973]  CC: (SUSE Linux) 4.3.4 [gcc-4_3-branch revision 152973
Wang_Ruifeng
     for example:
 static int testa(int a)
 static int testb(int b)
    return testa(b)
Patrick_F_Intel1
Can you post your VTune specific questions to the VTune forum: http://software.intel.com/en-us/forums/intel-vtune-amplifier-xe-and-vtune-performance-analyzer
Pat
