cancel
Showing results for
Search instead for
Did you mean:
今天是个悲伤的日子,我的Intel750SSDpci-e的硬盘坏了…
风风_宋
New Contributor
刚买了不到一个月……今天下午正在运行着windows7,突然就explorer报错,然后程序全都失去响应,按ctrl+alt+del也无效,之后死机了……
重启之后,我的天哪!这块intel750ssd就认不到硬盘了,bios里也看不到,就这样莫名其妙的就坏了……
我的资料啊!!!我的项目文档啊啊啊!!!Yoooooooooooooo!!!
4 REPLIES 4
Johnny_Y_Intel
New Contributor III
New Contributor III
宋风,你好!
很抱歉你的SSD出了故障,请尽快联系英特尔客户支持以便更换您的SSD:http://www.intel.cn/content/www/cn/zh/support/contact-support.html 联系支持人员
Esteemed Contributor III
Hello 宋风,
As per our translator application, we understand that your Intel® SSD 750 Series suddenly stopped being recognized in the BIOS.We can recommend testing the SSD in another PCIe* port, or in another system. Additionally, you may need to make sure your using the latest BIOS and Chipset Driver versions for your motherboard.If after this the drive is still not recognized, as Yanqiang suggested, the best thing to do will be to http://www.intel.cn/content/www/cn/zh/support/contact-support.html contact our support team.Note: While our world wide support community is in English, you may also post directly to our /community/chinesesupport Chinese Support Community.Best regards,Carlos A.
风风_宋
New Contributor
客服人员说要返回intel才能维修,要过15-30天才能有结果,好慢啊……我问他们能否换为同价位的其他硬盘,他们说不能,这pci-e的硬盘如此脆弱我还怎么敢用啊?!我就醉了……
750是英特尔PCIe SSD里面最便宜的一款,如果你要换同价位的其他硬盘,那就只能换730或者DC S3x00的硬盘,这对你来说其实是降级了,因为性能差别挺多的……其实总体来看,750的返修率并不高,可能你运气不太好,或者你也可以检查一下你目前使用的电源系统,因为SSD对电源要求比较高,如果电源输出不稳或者突然断电,都容易造成SSD损坏
