cancel
Showing results for
Search instead for
Did you mean:
Power On Hours count - SSD S4510 S4500
Dutra
New Contributor
I bought two 480GB S4510 SSD drives.
When analyzing the hours of use of each unit, I noticed that approximately 16 thousand hours of use are reported on both units.
I bought them like new.
Is it possible that there is a bug in this information?
1 REPLY 1
SolidigmKaren
Hi Tarcio,
Thanks for reaching out, happy to assist!
I would like to let you know that SSD Toolbox and Intel® SSD Data Center Tool Applications has reached end-of-life (EOL) and will no longer be updated.
I advise you to download the latest version of Solidigm™ Storage Tool (Intel® branded NAND SSDs) which is the 1.3. You can refer to the article outlined to download this tool.
Furthermore, if you ran a check with the tool I have provided and you still see the same information in regards to the hours of use I advise you to reach out to the store where you purchase those SSD's since they already have been used.
Hope this helps!
Best Regards!
