cancel
Showing results for
Search instead for
Did you mean:
ssd write speed problem on intel 6 and 7 series
agodk
New Contributor
hi there;
First of all i am not quite sure if i wrote this threat on right place. so sorry if its wrong.
i have problem with my ssd s in Intel chipsets. Ive 2 diffrent brand ssd s which is supports 500mb/s read and write.
i was tried this thing on my mobo which has z77a chipset with sata3 ports and also my laptop with mobile 6 series which is also have support for sata 3
so long story short with bothbrand ssd and either chipsets i can see 500mb/s read speeds but non of them can see more than 130 mb/s write speed with atto and cdm.
using latest RST and drivers also firmware for ssd s and bioses for mainboards. ah before forget i know its not affect that much but also i was tried with different sata cables.
what do you think about that?
ive really appreciate help
thnx.
regards
1 ACCEPTED SOLUTION
AP16
Contributor
Corsair Force GS series are based on SandForce, so peak speed writes possible only on compressible data, benchmarks usually avoids compression factor in tests.
3 REPLIES 3
AP16
Contributor
agodk
New Contributor
so what about kingston ssdnow300v series?
agodk
New Contributor
Thnx for answer JFF. after your reply i was tried with Sandisk so eveythings fine i was able to see 300mb/s
so i was choose wrong brand at first place.
Thnx and regards
