Community
cancel
Showing results for
Search instead for
Did you mean:
АКлеп2
Если сломается Intel® SSD DC S3110 на что поменяют по гарантии?
Jump to solution
Intel® SSD DC S3110 больше не выпускается, а поддержка есть?
LeonWaksman
  1. You don't need to register your SSD.
  2. Here you can check the warranty terms and coverage for your SSD.
  3. This page will help you how to identify your SSD.
Leon
JosafathB_Intel
Hello АКлеп2,
Thank you for contacting Intel® Memory & Storage Support.
As a friendly reminder, our service is provided in English only.
As stated in the product status in https://ark.intel.com/content/www/us/en/ark/search.html?_charset_=UTF-8&q=Intel%C2%AE+SSD+DC+S3110+S... the Intel® SSD DC S3110 Series status is discontinued, meaning that is not been manufacturer anymore, but since this product was released in 2017, the majority of this SSDs are covered under the 5 years warranty policy, meaning that we will provide you with the same or a similar SSD model in case that the warranty process is approved.
If you need technical support or a warranty replacement for your drive, please do not hesitate to let us know to begin with the troubleshooting process.
Josh B.
A Contingent Worker at Intel
АКлеп2
Спасибо за ответ, пока ssd работает.
Будем надеяться, что гарантия не пригодится. Тебуется ли регистрация продукции, как у других производителей? Как я понимаю - не тебуется.
АКлеп2
Тебуется-опечатка, правилно требуется.​
LeonWaksman
Leon
АКлеп2
Хорошо, спасибо.​
