Community
cancel
Showing results for
Search instead for
Did you mean:
Mayfat
Здравствуйте! В чём различия SSDPEKNW010T801 и SSDPEKNW010T8X1 ???
Jump to solution
Mayfat
Так в ЧЁМ различия???​ )
So WHAT are the differences???​)
LeonWaksman
There basically are the same. The SSDPEKNW010T8X1 is the newer model: https://www.amazon.co.uk/Intel-SSDPEKNW010T801-Solid-State-Drive-600p/dp/B07GBGHH39
Leon
Mayfat
JosafathB_Intel
Hello Mayfat, Thank you for contacting Intel® Memory & Storage Support. The answer provided by LWAKSMAN is correct. We will proceed to close this case since you already have an open case related to the same question with a different department. If you need further help please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
