Community
cancel
Showing results for
Search instead for
Did you mean:
ANoso2
Как перенести системный раздел жесткого диска на SSD при помощи Data Migration Software?
Сейчас в компьютере установлен HDD на 1Тб. Он разделен на три логических диска. Системный диск "С" имеет объем всего 99,9Гб. Был приобретен SSD объемом 256Гб, т.е. более чем в два раза больше текущего системного раздела. При попытке клонирования диска в Data Migration Software, программа сообщает, что исходный диск больше диска назначения. При этом, в исключении файлов я поставил в исключения все разделы диска, перенесен должен быть только системный раздел. Но программа требует освободить еще минимум 600Гб. Как быть? Почему программа работает некорректно?
n_scott_pearson
Super User Retired Employee
Actually, the program may not be working improperly. Its purpose is to clone one drive to another. If the drive has multiple partitions, then it is going to want to put all of these partitions onto the destination. Unless the program has an option to clone a single partition, you may have to archive the other partitions and then delete them before doing the clone.
Just saying,
ANoso2
The program has the ability to exclude unnecessary partitions and even folders and files. I mark everything that should be excluded from cloning, even deleted the "download" folder, in which there are a lot of files. The total amount of information for cloning turned out about 80GB.
JosafathB_Intel
Hello ANoso2, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello ANoso2, Thank you for having contacted Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
