cancel
Showing results for
Search instead for
Did you mean:
固态硬盘600固件不能更新
思陈1
New Contributor
固态硬盘不能更新固件,官网下载Intel SSD Toolbox(3.4.7),进行固件更新提示错我,(错误:固件更新进程出现错误 (10/53). 重启并重试。如果错误仍然存在,请使用位于 www.downloadcenter.intel.com 的 Intel 固件更新工具。)不知道要怎么才能进行固件更新,电脑安装了2块600p,一块256G一块1T都是不能进行更新的。
30 REPLIES 30
Esteemed Contributor III
Hi 鄧硯,
Thanks for the reply. There is a newer version of the Intel® Solid State Drive Toolbox https://downloadcenter.intel.com/download/27460/Intel-Solid-State-Drive-Toolbox?v=t 3.5.0. We recommend you to try with that version and let us know if you have the same results. If so, please provide a screenshot of the Toolbox showing the SSD information(Firmware). We look forward to hearing back from you.Regards,Junior M.
KTeng4
New Contributor
Hi, I also have the same problem, the new version can't fix my problem. My computer is Acer swift 3 SF315-51g-512g,and ssd firmware version is PSF109C.
YBai4
New Contributor
我觉得作为intel官方,600p这样的更新模式,是非常不合理而且不具有可操作性
首先,比较新的芯片组,肯定都是装win10,win10那必然是用UEFI而不是 legacy
如果我家里只有一台电脑,我怎么再找到一台legacy系统的,然后把UEFI的这台主机的ssd拔下来插另外一个上面,然后再升级固件?
用两个字形容,那就是扯淡
如果官方不推出能在UEFI基础上可以升级的软件,我以后再也不会买intel的ssd!
Hi 鄧硯駿,
We recommend you to try to update the Firmware with the Intel® SSD Firmware Update Tool. Please follow the next steps: 1- Go to: https://downloadcenter.intel.com/download/253482- Download the issdfut_2.2.3.iso3- Go to https://rufus.akeo.ie/ and download Rufus.4- Connect an empty USB flash drive to the PC.5- Open Rufus and change only the options "Device" and select your USB. Then go to ISO image, click on search and select the issdfut_2.2.3.iso you previously downloaded.6- Go to your BIOS -> Boot -> Boot priority -> select the "USB" as primary.7- Re-boot your PC. It should enter the firmware update tool for your SSD.8- Update the firmware and then boot windows.9- If it does not boot to the "USB" or it gives you an error, please go to BIOS and change the boot mode to "legacy only". Then try again.Please try it and let us know the results. NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.Hi yibai11, As per our translator tool, we would like to inform you that the tools are designed to work with the UEFI mode of your BIOS. With the Intel® SSD Firmware Update Tool we recommend as a workaround to change the BIOS mode on your system to "Legacy" because there are components of your system that may not allow you to update the Firmware when you are using the UEFI BIOS mode. Regards, Junior M.
KTeng4
New Contributor
Hi, my computer bios doesn't allow me to change the mode to the the legacy, it only has the UEFI mode, so I can't use firmware update tool to fix the problem. I already tired it.
