Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
02HA Poll.
UPDATE 10-31-09 @3:20p
I=IDE
A=AHCI
R=RAID
BRAND NEW
III - GOOD=01 BAD=00
AAA - GOOD=02 BAD=00
AIA - GOOD=02 BAD=00
RIR - GOOD=00 BAD=01
INSTALLED (NO REFORMAT/ERASE)
III - GOOD=03 BAD=00
AAA - GOOD=06 BAD=02
AIA - GOOD=05 BAD=04
RAR - GOOD=02 BAD=00
RIR - GOOD=03 BAD=00
REFORMAT/ERASE
AAA - GOOD=01 BAD=00
AIA - GOOD=01 BAD=00
IIA - GOOD=01 BAD=00
Also reworded some of the questions. PLEASE POST ANSWERS ONLY. Thx
Hey, guys, I think we should take some info of those who updated their g2's. It's really hard to see what's going. I think people should list the stuff on their computer and what was on it before the firmware flash. It might be a lot easier to see a commonality. In my opinon, Intel should have made the flash update a destructive one. Wipe the drive off clean before updating the flash. That way a lot of variables for error is reduced. I have a feeling the trim command is getting some instructions all messed up with a filesystem already present. Yeah i know it's a lot of questions but...
Here' it goes...
1-Bios updated to Latest? (YES or NO)
2-What g2 size 80 or 160g? (80 or 160)
3-Was drive BRAND NEW / ERASED (hdd erase/reformat)/ INSTALLED (OS already installed) before update?
4-Is the drive partitioned? (YES or NO)
5-other harddrives installed? (YES or NO)
6-Was drive aligned BEFORE and AFTER update?
7-OS that you have installed or will be installing?
8-If using windows and already installed, what driver is being used before updating firmware? (Intel or MS, AHCI, IDE) if applicable
9-Bios setting before update? (IDE, AHCI, RAID, etc)
during update? (IDE, AHCI, RAID, etc)
after update? (IDE, AHCI, RAID, etc)
10-Did you run the flasher via USB or CD?
11-How many times did you run the flasher? (1x, 2x, 3x)
12-Was there an error when flashing? (YES or NO)
13-After it flashed and the computer rebooted, did you immediately change the settings back to what it was before booting/installing OS? (YES or NO)
14-When booted in Windows did it install a driver? (YES or NO) if applicable
15-What driver did it install?
16-If possible, what driver is being used in Windows after firmware? (Intel or MS, AHCI, IDE)
17-Is the G2 drive bad or working fine? (BAD or GOOD)
List your system specs too and if possible chipset (south bridge chip)
List you SSD manufacturing date.
Anything else you think I missed please say.
***FOR THOSE WITH BAD DRIVES AFTER UPDATE DID YOU TRY TO HDD ERASE AND REINSTALL? If so, did it work again?
***Don't do it if you're not comfortable with it.
Hopefully the information given can help INTEL resolve this issue quicker as it seems to be easier to get information quicker on the forums than individual emails.
Community Manager
1-Bios updated to Latest? YES
1-What g2 size 80 or 160g? 160
2-Is the drive partitioned? NO
3-other harddrives installed? NO
3-Was windows 7 Installed already or was it clean? CLEAN
4-What version of 7, x86, x64? CLEAN
5-Was it aligned before and after update? not sure, was BRAND NEW
6-Did you reformat or leave windows on before update? BRAND NEW
7-Was Intel optimizer installed before or after update? NEITHER, WIN 7
8-If optimizer was Installed before the update did you run it? N/A
9-Bios and windows setting before update? (IDE, AHCI, RAID, etc) not sure, default setting, no RAID
10-Setting during update? (IDE, AHCI, RAID, etc) not sure, default setting, no RAID
11-Setting after update? (IDE, AHCI, RAID, etc) not sure, default setting, no RAID
12-Did you run the flasher twice before booting or installing Win7? 1x
13-Was there an error when flashing? NO
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? NEW INSTALL
15-When booted in Windows 7 did it install a driver? NEW INSTALL
16-Is the G2 drive bricked or working fine? GOOD
ThinkPad X61 Tablet.
Community Manager
1-What g2 size 80 or 160g? 80
3-other harddrives installed? YES
3-Was windows 7 Installed already or was it clean? INSTALLED
4-What version of 7, x86, x64? x64
5-Was it aligned before and after update? Dont know...how do I tell?
6-Did you reformat or leave windows on before update? Is this the same as # 3? Installed before update
7-Was Intel optimizer installed before or after update? AFTER
8-If optimizer was Installed before the update did you run it? YES
9-Bios and windows setting before update? IDE - My Bios doesn't have any options (Gateway)
10-Setting during update? IDE
11-Setting after update? IDE
12-Did you run the flasher twice before booting or installing Win7? 2x per the instructions
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? No change
15-When booted in Windows 7 did it install a driver? I dont think so. It rebooted but I dont think there was a new driver installed. There is no option to rollback the driver.
Community Manager
2-Is the drive partitioned? No
5-Was it aligned before and after update? I assume so
6-Did you reformat or leave windows on before update?INSTALLED
9-Bios and windows setting before update? RAID (only sey for HD RAID arrays)
10-Setting during update? AHCI (fw update wouldn't see SSD unless set to this)
11-Setting after update? RAID
12-Did you run the flasher twice before booting or installing Win7? 2x (second time to check fw had taken)
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? YES
15-When booted in Windows 7 did it install a driver? YES
PC spec:
Asus P6T Deluxe v1
i7 920
6gb
nVidia GTX 285
Intel G2 160gb (system)
3x WD 1TB hard disks in RAID 5
2x Segate 320GB hard disks in RAID1
Community Manager
1-Bios updated to Latest? NO (Latest brings only support for new CPUs)
2-Is the drive partitioned? YES (Win7 100MB system partition is the second partition)
6-Did you reformat or leave windows on before update? INSTALLED
7-Was Intel optimizer installed before or after update? AFTER (on the first bootup)
9-Bios and windows setting before update? BIOS: AHCI Windows: AHCI
10-Setting during update? IDE (fw update wouldn't see SSD unless set to this)
11-Setting after update? AHCI
16-Is the G2 drive bricked or working fine? BRICKED!
PC spec:
Asus P5B
Q6600
4GB DDR2
ATI HD5850
SB X-Fi Xtreme Gamer
Intel X25-M G2 80gb (system)
3 other SATA hard disks
1 other PATA hard disk
Windows 7 Ultimate 64bit (MSDN)
Community Manager
2-What g2 size 80 or 160g? 80
3-Is the drive partitioned? YES
4-other harddrives installed? NO
5-What version of 7, x86, x64? 7 x86
6-Was windows 7 Installed already or was it clean? INSTALLED
7-Was it aligned before and after update? BEFORE
8-Did you reformat or leave windows on before update? INSTALLED
9-Was Intel optimizer installed before or after update? AFTER
10-If optimizer was Installed BEFORE the update did you run it? N/A
11-Bios and windows setting before update? AHCI
12-Setting during update? AHCI
13-Setting after update? AHCI
14-Did you run the flasher twice before booting or installing Win7? 1x
15-Was there an error when flashing? NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? N/A-NEVER CHANGED ANYTHING
17-When booted in Windows 7 did it install a driver? YES
18-Is the G2 drive bricked or working fine? GOOD
System is Dell XPS M1330, 2.2GHz T7500, ICH8M, 4GB, GeForce 8400M GS
Community Manager
4-other harddrives installed? YES
5-What version of 7, x86, x64? Windows 7 Professional x64
7-Was it aligned before and after update? BEFORE, I think windows 7 does this automatically when it was installed.
9-Was Intel optimizer installed before or after update? BEFORE
10-If optimizer was Installed BEFORE the update did you run it? YES, but trim was not possible (of course), because fw was not installed yet
14-Did you run the flasher twice before booting or installing Win7? TWICE
18-Is the G2 drive bricked or working fine? WORKING FINE
System is homebuilt asus p5b-deluxe wifi, 8800gt, q9300, 3gb RAM, SSD:X25M-G2 80Gb, HDDs: 1,5Tb seagate, 750gb Samsung
Community Manager
Hope this thread helps them (I think its a very good idea! )
1-Bios updated to Latest? - YES
2-What g2 size 80 or 160g? - 80
3-Is the drive partitioned? - NO (no additional partitions, just the primary one)
4-other harddrives installed? - YES
5-What version of 7, x86, x64? Vista x64
6-Was windows 7 Installed already or was it clean? Visa-Installed
7-Was it aligned before and after update? - Yes
8-Did you reformat or leave windows on before update? - INSTALLED
9-Was Intel optimizer installed before or after update? - AFTER
10-If optimizer was Installed BEFORE the update did you run it? -
11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) - IDE
12-Setting during update? (IDE, AHCI, RAID, etc) - IDE
13-Setting after update? (IDE, AHCI, RAID, etc) - IDE
14-Did you run the flasher twice before booting or installing Win7? - 1x
15-Was there an error when flashing? - YES, read error on drive a:, did a retry, then a ignore. Reported flash was succesful.
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? - NO, did not change settings
17-When booted in Windows 7 did it install a driver? - Vista, YES
System:
Asus P6T SE
Intel Core i7 920 @ 3.2 MHz
Asus GTX275
Intel Postville G2 80GB + Samsung Spinpoint F3 1TB
6GB Kingston 1600 memory
Community Manager
5-What version of 7, x86, x64? Windows 7 x64
7-Was it aligned before and after update? I think so.
10-If optimizer was Installed BEFORE the update did you run it? NO
12-Setting during update? IDE
14-Did you run the flasher twice before booting or installing Win7? NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? YES
17-When booted in Windows 7 did it install a driver? YES (SSD)
Hardware:
Acer Aspire 8930G
4GB RAM
add. Samsung 2,5" 500GB HDD
Community Manager
2-What g2 size 80 or 160g? 160
3-Is the drive partitioned? only other partition is the 100MB startup partion that Windows 7 creates upon installation
5-What version of 7, x86, x64? Windows 7 Enterprise x64 RTM from MSDN (it's activated)
7-Was it aligned before and after update? YES / YES
10-If optimizer was Installed BEFORE the update did you run it? YES (only reported that the drive firmware needed an upgrade for it to function)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? N/A (no change)
17-When booted in Windows 7 did it install a driver? YES (it installed something that required a restart, not sure it was a driver though)
19-TRIM support? ACTIVE
20-Encryption? YES (the drive is Bitlocker encrypted and was so even before the firmware upgrade)
Lenovo ThinkPad T61 with 4GB RAM
Community Manager
3-Is the drive partitioned? NO
5-What version of 7, x86, x64? Win 7 Pro x64
7-Was it aligned before and after update? YES (both)
10-If optimizer was Installed BEFORE the update did you run it? n/a
11-Bios and windows setting before update? RAID
13-Setting after update? RAID
17-When booted in Windows 7 did it install a driver? NO
System Spec:
Intel DX58SO
Core i7 950
6GB DDR3
NVIDIA 9800 GX2
Intel X25-M G2 80GB
WD VelociRaptor
2x WD Raptor X (RAID0)
ASUS Xonar DX
Community Manager
1-Bios updated to Latest? (YES or NO) YES
2-What g2 size 80 or 160g? (80 or 160) 80
3-Is the drive partitioned? (YES or NO) NO
4-other harddrives installed? (YES or NO) YES
5-What version of 7, x86, x64? (using or will be using) X64
6-Was windows 7 Installed already or was it clean? (INSTALLED or CLEAN) INSTALLED
8-Did you reformat or leave windows on before update?(INSTALLED or ERASED or BRAND NEW) INSTALLED
9-Was Intel optimizer installed before or after update? (BEFORE or AFTER) AFTER
10-If optimizer was Installed BEFORE the update did you run it? (YES or NO) N/A
11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) -list both if applicable AHCI
12-Setting during update? (IDE, AHCI, RAID, etc) IDE
13-Setting after update? (IDE, AHCI, RAID, etc) AHCI
14-Did you run the flasher twice before booting or installing Win7? (1x, 2x, 3x) 2X
15-Was there an error when flashing? (YES or NO) NO
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (YES or NO) YES
17-When booted in Windows 7 did it install a driver? (YES or NO) YES
18-Is the G2 drive bricked or working fine? (BAD or GOOD) GOOD
WIN 7 ULTIMATE
CORE I7 920
ASROCK X58 EXTREME
3GB OCZ
VARIOUS OTHER HD
Community Manager
To check alignment, run this command from a command line (Start, type "cmd" into the search box):
wmic partition get BlockSize, StartingOffset, Name, Index
This is what an unaligned partition looks like. Mine is a leftover from XP days, upgraded to Vista and then again to 7:
BlockSize Index Name StartingOffset
512 0 Disk # 0, Partition # 0 32256
That's a 63 sector offset. What were they thinking.
An aligned partition created by Vista / 7 will have an offset of 2048 blocks, which will look like this:
512 0 Disk # 0, Partition # 0 1048576
Running an SSD unaligned is throwing performance away. Your SSD "thinks" in 4k flash "pages". If you're mis-aligned, filesystem clusters span across flash pages, which means a very real performance hit.
Quick aside: For any SAN, Exchange Server, SQL Server, anything with a RAID, even when using HDDs, alignment is also crucial. The amount of admins that don't know this and throw 20-30% performance away is maddening. Give this to your sysadmin and have her take it to heart: http://blogs.msdn.com/jimmymay/archive/2009/05/08/disk-partition-alignment-sector-alignment-make-the...
I think the picture that is emerging so far seems to be the best explanation:
- TRIM or "Optimize" is causing the issue
- Only when the boot partition is misaligned
It'd be great to know whether those people with failures have misaligned partitions. Obviously, you can't run wmic when your drive's bricked. Or, let's say, only with "great difficulty". Here's a way to estimate:
1) Did Vista or Windows 7 create the partition that ended up on this drive? This would be the case if the Vista / Windows 7 install was run on a completely unpartitioned, unformatted drive; or if you opted to delete the existing XP partition during install. That latter action is very much user-driven - you'd know if you'd done that. If yes: Your partition is aligned.
2) Did Vista or Windows 7 "inherit" an XP partition? This would be the case if you did in-place upgrades to Vista and then Windows 7, or if you ran a fresh install of Vista / Windows 7 but did not instruct the installer to delete your existing XP partition. By default, the installer will re-use the existing partition, not delete it; it may also have created a "windows.old" folder. If yes: Your partition is unaligned.
Community Manager
Just curious, how did you come to conclusion that misalignment is the cause of the problem? All posters but 1 in this thread report no problems.
Thanks for the neat way to check alignment.
Community Manager
It's not a conclusion, and it's not mine. It's a premise put forth by another poster in the "Windows 7 and bricked drive after upgrade" thread. It'd make sense in that:
- We now see the issue in Vista after a few days
- Which means it's likely related to the freeing of blocks
- Which happens automatically in Win7 through TRIM, so that's where it's been seen first
- TRIM lets the drive know which file system clusters can be reclaimed. On an aligned drive and assuming default 4k NTFS clusters, each cluster corresponds neatly to 1 flash page. On an unaligned drive, it doesn't: Each cluster spans part of two adjacent flash pages. Lots of potential to get the freeing of flash pages in that scenario wrong, as you can imagine.
It's the best premise I've heard so far. Now it's a matter of collecting data. If we get an overwhelming number of people with bad drives reporting that their partitions were unaligned, and an overwhelming number of people with good drives reporting that their partitions are aligned, the premise would be strengthened.
Community Manager
1-Bios updated to Latest? (YES)
2-What g2 size 80 or 160g? (160)
3-Is the drive partitioned? (YES)
4-other harddrives installed? (YES)
5-What version of 7, x86, x64? (x64)
6-Was windows 7 Installed already or was it clean? (INSTALLED)
7-Was it aligned before and after update? (BEFORE)
8-Did you reformat or leave windows on before update?(BRAND NEW)
9-Was Intel optimizer installed before or after update? (AFTER)
11-Bios and windows setting before update? (AHCI) -list both if applicable
12-Setting during update? (AHCI)
13-Setting after update? (AHCI)
14-Did you run the flasher twice before booting or installing Win7? (1x)
15-Was there an error when flashing? (NO)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (NO)
17-When booted in Windows 7 did it install a driver? (YES)
18-Is the G2 drive bricked or working fine? (GOOD)
Asus PTD6 Deluxe
6GB RAM
ITB Samsung HDD
Radeon 4870
Asus Xonar Essence STX
Community Manager
3-Is the drive partitioned? (NO)
5-What version of 7, (x64)
6-Was windows 7 Installed already or was it clean? (CLEAN)
7-Was it aligned before and after update? (Auto aligned by 7/64)
8-Did you reformat or leave windows on before update?( ERASED )
10-If optimizer was Installed BEFORE the update did you run it? (N/A)
12-Setting during update? (IDE)
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (YES )
17-When booted in Windows 7 did it install a driver? (NO)
ASUS ICH9
QX 6850
6GB DDR3 RAM
G2 80 GB (Data only)
4870x2
Asus Xonar DX2
Community Manager
3-Is the drive partitioned?YES
5-What version of 7, x86, x64? 7 x64
9-Was Intel optimizer installed before or after update? NOT
18-Is the G2 drive bricked or working fine? BAD
DZand
Valued Contributor I
Here is my report:
1-YES
2-160
3-YES
4-NO
5-Win7 x64
6-INSTALLED
7-YES
8-INSTALLED
9-AFTER
10-not applicable
11-RAID
12-IDE
13-RAID
14-2x
15-NO
16-YES
17-NO
18-GOOD
Answers to maybe important additional questions:
19-Which IDE/SATA/RAID driver was running before updating the firmware: Intel RST SATA RAID driver v9.5.0.1037
20-Which IDE/SATA/RAID driver was running after updating the firmware: Intel RST SATA RAID driver v9.5.0.1037
My system:
MB: GIGABYTE GA-EP45-UD3R
CPU: Intel Core2Duo E8400 @ 3,00 Ghz
Chipset: Intel ICH10R
HDD's: 2x 160 GB Intel X25-M SSD as RAID0
RAM: 4x2 GB G.Skill PC2-8500
Community Manager
4-What version of 7, x86, x64? x86
14-After it flashed and the computer started, did you immediately change the settings back to what it was before booting into windows? NO
PC spec:
Asus P7P55D
i5 720
4gb
nVidia GTX 260
Intel G2 80gb (system)
3 x Seagate 500GB hard disk in IDE
Corsair HX650
Community Manager
3-Is the drive partitioned? (YES or NO) YES (Win7 configured it as part of initial on a clean disk)
4-other harddrives installed? (YES or NO) YES (2xWD 1TB in RAID1 as data drives)
5-What version of 7, x86, x64? (using or will be using) Win7 Home x64 RETAIL
6-Was windows 7 Installed already or was it clean? (INSTALLED or CLEAN) Clean: fresh install
7-Was it aligned before and after update? N/A
8-Did you reformat or leave windows on before update?(INSTALLED or ERASED or BRAND NEW) BRAND NEW
9-Was Intel optimizer installed before or after update? (BEFORE or AFTER) BEFORE
10-If optimizer was Installed BEFORE the update did you run it? (YES or NO) YES (and it stated that the drive FW needed updating, but displayed drive data like SMART, etc.)
11-Bios and windows setting before update? (IDE, AHCI, RAID, etc) -list both if applicable RAID
13-Setting after update? (IDE, AHCI, RAID, etc) RAID
14-Did you run the flasher twice before booting or installing Win7? (1x, 2x, 3x) 1x
15-Was there an error when flashing? (YES or NO) No
16-After it flashed and the computer started (Windows was installed before update), did you immediately change the settings back to what it was before booting into windows? (YES or NO) Yes
17-When booted in Windows 7 did it install a driver? (YES or NO) Yes
18-Is the G2 drive bricked or working fine? (BAD or GOOD) BAD
System specs:
DFI LP UT X58-T3eH8 w/ D619 FW
Core i7 920 w/ Zalmon 9000 (not O/C)
3x2GB OCZ 10666
1xIntel 80GB G2 SSD (boot)
2xWD 1TB RAID1 (data)
Sapphire Radeon 5870
Antec 850W Signature PSU
Antec P182 case
