cancel
Showing results for
Search instead for
Did you mean:
1.7 update
Esteemed Contributor III
My system is running fine is there a need to upgrade to the lastest firmware?
12 REPLIES 12
I just intalled an x25m 160gb ssd and it's running great; but when I try to update the firmware it says "no intel ssd found or disabled" What do I do now?
You need to tell us what your PC configuration is, such as mother board model and what interface you are using for your SSD before we can offer any assistance.
Set SATA Mode to IDE (or Compatibility). Apply update and then restore the mode.
SKlin
New Contributor
Just installed the firmware update on my 80 gig and 40 gig ssds. Was easy and worked well.
skline00, Sounds good, but just for our information, was your 40GB SSD of the new 'V' line of SSDs?
