Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
1.8" SSD compatibility
Hi folks,
Does anyone know if the Intel 1.8" SSDs (SSDSA1MH160G201) are compatible and fit into HP2540Ps that use the 1.8" inch drive space?
Thanks in advance.
David
Community Manager
Not sure.... but it comes in 1.8" hard drive form factor and is 5mm thick. What are the dimensions of the existing drive?
Community Manager
I was told by Crucial that their RealSSD C300 CTFDDAA128MAG-1G1 1.8" 128GB SATA III MLC Internal Solid State Drive (SSD) was compatible and the size of it is 78.5 x 54.0 x 5.0 mm and I was told by Kingston that their drive Kingston SSDNow V+ 180 SVP180S2/128G was also compatible and it is 54 x 78.5 x 5 mm
Community Manager
Yes, that drive fits without problems. I have a HP2530P with that drive. The HP2540P is an evolution of the same laptop.
Community Manager
thanks Pub, first hand information helps.
I also have a 2530P, like it so much that I'm selling it and buying a 2540P. Glad to know I shouldn't have installation issues.
How do you like your SSD? Any special likes/dislikes? I assume you saw a dramatic speed increase. I plan on using
Intel's SSD Toolbox, do you use that?
David
Community Manager
You're wellcome.
The drive is amazing. The overall speed is incredible in comparison with the built-in drive of the laptop. I'm using Windows 7 Pro x64, and for that I don't need use the SSD Toolbox. My only advice is "never try use the actual Intel drivers" (RST 9.6). When I tried use it, the Win7 not booted up again. In the last attempt I had to reinstall all the operating system because even uninstalling it, Windows begans to have a lot of strange troubles.
Put you bios to AHCI mode and trust in the built-in Win7 drives with TRIM support. You'll don't have any troubles.
Community Manager
thanks for the warning Pub. I'm using Win 7 64 bit also. The drive I'm going to clone to the SSD has Intel Storage Mgr 8.6. I guess I should take that off of the machine before I set up the SSD and just let Win 7 take care of Trim and things instead of using Toolbox.
Community Manager
I would still use the Intel AHCI drivers for optimal performance. They do support TRIM.
The SSD Toolbox is not needed for garbage collection or optimization. However, it does provide other useful tools.
