Community
cancel
Showing results for
Search instead for
Did you mean:
JJosh2
1TB 600p Not showing in Disk Management.
Jump to solution
Just got 1TB 600p M.2 SSD and it's not showing up in Disk Management. It does show up in my boot menu however. It also appears in Device Manager, but under 'Other Devices' listed as 'PCI Device'.
I've hit a wall, I downloaded the Intel SSD Toolbox and Driver Update Utility Installer to see if they would pick it up, neither did. I've looked through similar threads but none seem to have the answer I'm looking for, any suggestions?
Tags (1)
JJosh2
Needed windows 7 hot fix for drivers required for NVMe support.
JJosh2
