Community
cancel
Showing results for
Search instead for
Did you mean:
AndreBorchert
2x 545S 1TB FW Update error 10/53
I have two Lenovo T520 notebooks and upgraded them this way:
  • One notebook has a new 545S 1TB drive
  • The other has a 545S 512GB as boot drive and a 545S 1TB as a Dropbox drive.
All drives are new. The 512GB drive required a FW update which was done within Windows using the SSD Toolbox 3.5.7. The two 1TB drives refuse to accept the FW update, no matter if I use the SSD Toolbox or the SSD Firmware Update Tool ISO 3.0.5 from a USB pen.
The error in the SSD Toolbox is shown as "10/53". The error from the Firmware Update ISO is shown in the attached picture. As the same error happens on two different notebooks with brand new 1TB drives from Amazon I am worried that there is a general issue with the 545S 1TB drives. All drives run in AHCI mode, Intel Chipset driver 10.1.1.42 installed. There are no issues to use the drives, speeds are as expected.
Both 1TB drives have the FW LHF0B1C and are supposed to be updated to LHF0B2C.
Please advise how to update the FW on the 1TB drives. Both are in daily business use and I cannot replace them at this time.
Many thanks for checking,
Andre
JosafathB_Intel
Hello AndreBorchert, Thank you for contacting Intel® Technical Support. As we understand, you need assistance with your Intel® SSD 545s Series (1.024TB). If we infer correctly we will appreciate if you can provide us with the following information: • The SSU logs. 1- Go to https://downloadcenter.intel.com/download/26735/ and download the software. 2- When finished downloading it, open it. 3- Attach the file obtained to your reply. • A screenshot of the “Disk Management” of windows showing all your HDDs and partitions (this to have a better view on how your SSD is detected by the OS) • The SMART details .CSV file (SMART logs) from your Intel® SSD 540s Series. In the “IntelSolidStateDriveToolboxUserGuide.pdf” (https://www.intel.com/content/dam/support/us/en/documents/memory-and-storage/IntelSolidStateDriveToo...) section 3.2 you can find the instructions on how to get this file. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
AndreBorchert
Hello Josh,
all files attaced as requested.
Many thanks,
Andre
AndreBorchert
Please find attached the logs from the second notebook which has only 1x 545S 1TB drive.
AndreBorchert
And here the error message 10/53 from the SSD Toolbox, which is the same on both notebooks ..
JosafathB_Intel
Hello AndreBorchert, Thank you for your reply. We are going to be working on reviewing the information you shared with us and in trying to reproduce the issue you are reporting in our lab. We will be contacting you back as soon as we have an update or in case that further information is required. Have a nice day. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello AndreBorchert, Thank you for your patience. The root cause has been determined to be a missing firmware update configuration in the tools for this Intel® SSD 545s Series (1.024TB). This is now being updated to the tools and will be available soon. We advise you to keep an eye on the https://downloadcenter.intel.com/ for an update on the Intel® Solid State Drive Toolbox. We hope you find this information helpful. If you need further assistance please do not hesitate to contact us again Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
AndreBorchert
Thank you Josh ! :)
JosafathB_Intel
Hello AndreBorchert, Thank you for your reply. We will like to know if you need further assistance or if we can close this case. Important note: Should further assistance or clarification be required, we will greatly appreciate if you reply to this post instead of writing a new one unless your inquiry is completely unrelated. This way we will prevent generating a duplicate post and we will not lose the train of thought. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
AndreBorchert
Hi Josh, you can close this case now, thanks !
JosafathB_Intel
Hello AndreBorchert, Thank you for your reply. As per your consent, this case is now closed. If you need further assistance please do not hesitate to contact us. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
