Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
2x510 120GB RAID 0 on MSI 890FXA-GD70 w/ AMD SB850 Lockups and BSOD
I am getting hard lockups and BSOD from the following hardware. All drivers are the latest from MSI website. I have swapped power supplies. I have swapped identical RAM. I have swapped video cards. I have used Ultimate Boot CD to run Memtest and other stress tests and everything passes with flying colors. BIOS is loaded with defaults fail safe. RAID array is created using all defaults for a RAID 0. Everything points to SSD firmware or other issues. Maybe RAID 0 with 2 510's using a AMD SB850 is not supported? Firmware versions on the 510's are both PPG4 which is the latest. Am I doing something wrong? Anyone have any ideas? I am very disappointed that that I can not get my RAID 0 stable. BTW I am doing no overclocking etc. Hardware and errors follow. Thanks!
OS: WIN7x64
MB: MSI 890FXA-GD70 w/ latest BIOS
CPU: AMD Phenom II X6 1100T
HD: 2xIntel SSD 510 120GB SSD RAID 0
VID: ATI FirePro V4800
RAM: G.SKILL Ripjaws Series 8GB (4 x 2GB) 240-Pin DDR3 1600 F3-12800CL9D-4GBRL
  1.
    Microsoft (R) Windows Debugger Version 6.12.0002.633 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [D:\Kingston\BSODDmpFiles\chapmunger\Windows_NT6_BSOD_jcgriff2\031112-15210-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7601 (Service Pack 1) MP (6 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7601.17640.amd64fre.win7sp1_gdr.110622-1506 Machine Name: Kernel base = 0xfffff800`02c5a000 PsLoadedModuleList = 0xfffff800`02e9f670 Debug session time: Sun Mar 11 00:13:13.124 2012 (UTC - 6:00) System Uptime: 0 days 0:04:46.289 Loading Kernel Symbols ............................................................... ................................................................ .............................. Loading User Symbols Loading unloaded module list ....... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck D1, {fffff88001308c08, 2, 8, fffff88001308c08} Probably caused by : Ntfs.sys ( Ntfs! ?? ::NNGAKEGL::`string'+2bf0 ) Followup: MachineOwner --------- 4: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1) An attempt was made to access a pageable (or completely invalid) address at an interrupt request level (IRQL) that is too high. This is usually caused by drivers using improper addresses. If kernel debugger is available get stack backtrace. Arguments: Arg1: fffff88001308c08, memory referenced Arg2: 0000000000000002, IRQL Arg3: 0000000000000008, value 0 = read operation, 1 = write operation Arg4: fffff88001308c08, address which referenced memory Debugging Details: ------------------ READ_ADDRESS: GetPointerFromAddress: unable to read from fffff80002f09100 fffff88001308c08 CURRENT_IRQL: 2 FAULTING_IP: Ntfs! ?? ::NNGAKEGL::`string'+2bf0 fffff880`01308c08 55 push rbp CUSTOMER_CRASH_COUNT: 1 DEFAULT_BUCKET_ID: VISTA_DRIVER_FAULT BUGCHECK_STR: 0xD1 PROCESS_NAME: explorer.exe TRAP_FRAME: fffff8800a580fb0 -- (.trap 0xfffff8800a580fb0) NOTE: The trap frame does not contain all registers. Some register values may be zeroed or incorrect. rax=fffff88001308c08 rbx=0000000000000000 rcx=fffff8800a581180 rdx=fffff8800a582770 rsi=0000000000000000 rdi=0000000000000000 rip=fffff88001308c08 rsp=fffff8800a581148 rbp=fffff8800a581280 r8=fffff8800a581900 r9=fffff8800a581280 r10=fffff8800a582970 r11=fffff8800a5811b8 r12=0000000000000000 r13=0000000000000000 r14=0000000000000000 r15=0000000000000000 iopl=0 nv up ei ng nz na pe nc Ntfs! ?? ::NNGAKEGL::`string'+0x2bf0: fffff880`01308c08 55 push rbp Resetting default scope LAST_CONTROL_TRANSFER: from fffff80002cd61e9 to fffff80002cd6c40 FAILED_INSTRUCTION_ADDRESS: Ntfs! ?? ::NNGAKEGL::`string'+2bf0 fffff880`01308c08 55 push rbp STACK_TEXT: fffff880`0a580e68 fffff800`02cd61e9 : 00000000`0000000a fffff880`01308c08 00000000`00000002 00000000`00000008 : nt!KeBugCheckEx fffff880`0a580e70 fffff800`02cd4e60 : 00000000`000000e9 00000000`00000000 fffff800`02ce1845 fffff880`01269840 : nt!KiBugCheckDispatch+0x69 fffff880`0a580fb0 fffff880`01308c08 : fffff800`02d02a7c 00000000`00000001 fffffa80`09667000 fffffa80`08c92d01 : nt!KiPageFault+0x260 fffff880`0a581148 fffff800`02d02a7c : 00000000`00000001 fffffa80`09667000 fffffa80`08c92d01 fffffa80`08d1aea0 : Ntfs! ?? ::NNGAKEGL::`string'+0x2bf0 fffff880`0a581150 fffff800`02d024fd : fffff880`01269834 fffff880`0a582770 00000000`00000000 fffff880`01219000 : nt!_C_specific_handler+0x8c fffff880`0a5811c0 fffff800`02d012d5 : fffff880`01269834 fffff880`0a581238 fffff880`0a5820a8 fffff880`01219000 : nt!RtlpExecuteHandlerForException+0xd fffff880`0a5811f0 fffff800`02d12361 : fffff880`0a5820a8 fffff880`0a581900 fffff880`00000000 ffff5fff`ffffffff : nt!RtlDispatchException+0x415 fffff880`0a5818d0 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiDispatchException+0x135 STACK_COMMAND: kb FOLLOWUP_IP: Ntfs! ?? ::NNGAKEGL::`string'+2bf0 fffff880`01308c08 55 push rbp SYMBOL_STACK_INDEX: 3 SYMBOL_NAME: Ntfs! ?? ::NNGAKEGL::`string'+2bf0 FOLLOWUP_NAME: MachineOwner MODULE_NAME: Ntfs IMAGE_NAME: Ntfs.sys DEBUG_FLR_IMAGE_TIMESTAMP: 4d79997b FAILURE_BUCKET_ID: X64_0xD1_CODE_AV_BAD_IP_Ntfs!_??_::NNGAKEGL::_string_+2bf0 BUCKET_ID: X64_0xD1_CODE_AV_BAD_IP_Ntfs!_??_::NNGAKEGL::_string_+2bf0 Followup: MachineOwner ---------
  2. Loading Dump File [D:\Kingston\BSODDmpFiles\chapmunger\Windows_NT6_BSOD_jcgriff2\031012-22963-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols http://msdl.microsoft.com/download/symbols Executable search path is: Windows 7 Kernel Version 7600 MP (6 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 7600.16841.amd64fre.win7_gdr.110622-1503 Machine Name: Kernel base = 0xfffff800`0285a000 PsLoadedModuleList = 0xfffff800`02a97e70 Debug session time: Sat Mar 10 22:15:14.047 2012 (UTC - 6:00) System Uptime: 0 days 0:02:55.014 Loading Kernel Symbols ............................................................... ................................................................ ............. Loading User Symbols Loading unloaded module list ..... ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* Use !analyze -v to get detailed debugging information. BugCheck F4, {3, fffffa8009348b30, fffffa8009348e10, fffff80002bd2300} Probably caused by : hardware_disk Followup: MachineOwner --------- 3: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* CRITICAL_OBJECT_TERMINATION (f4) A process or thread crucial to system operation has unexpectedly exited or been terminated. Several processes and threads are necessary for the operation of the system; when they are terminated (for any reason), the system can no longer function. Arguments: Arg1: 0000000000000003, Process Arg2: fffffa8009348b...
Tags (2)
