cancel
Showing results for
Search instead for
Did you mean:
320 / 600 GB in Proliant DL380/G7 - shows as overheating
Esteemed Contributor III
Just installed 5 of these in a RAID configuration on a test server. Working perfectly, except:
The server is reporting that the drives are overheating (they're not). It appears that possibly I can turn OFF DIPM on these drives and the SMART info will be reported correctly.
How do I do that?
FYI, running windows 2008 r2
Rob
46 REPLIES 46
Let me check if Intel get the email.
Any response from them?
Rob
we are facing the same issue.
greatly appreciate a rapid solution.
thanks!
All,
I'm working to get you an update. Haven't forgotten about this
-Scott, Intel Corporation
