Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
512GB SSD M.2 NVMe INTEL SSDSCKKF512H6 0X8V6H 电路板照片
1342
固态硬盘出现问题,无法打开,里面有非常重要的数据需要恢复,数据恢复中心需要一个同规格的​硬盘电路照片作为对比,不知道官方是否可以提供硬盘照片。
原始硬盘如下,需要同规格的没有标签的照片,可以看到电路板。非常感谢​
JosafathB_Intel
Hello 3000021808931.555927369479085E12, Thank you for contacting Intel® Memory & Storage Support. As we understand, you need assistance with your Intel® SSD Pro 5400s Series (512GB, M.2 80mm SATA 6Gb/s, 16nm, TLC). If we infer correctly we will like to share the following recommendations and information: 1. Please note that your SSD is an OEM SSD from Dell* and it may be different from our generic Intel® SSD Pro 5400s Series SSDs. 2. Removing the sticker that contains the markings of your SSD will void your product warranty. 3. The information regarding the SSD circuit board is not available to the public. The requested documentation/information can be provided under the Non-Disclosure Agreement (NDA) only. *NDA - A contract between two or more parties where the subject of the agreement is a promise that the information conveyed will be maintained in secrecy. Do you have an NDA signed with Intel® previously? If you have can you provide us with your NDA number? We strongly advise you to contact your SSD OEM (original equipment manufacturer) in this case Dell* to get further assistance for your product. This based on the fact that some hardware or software (firmware) component might have been changed or replaced by the computer manufacturer. Thank you for your patience and understanding. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
AlHill
If your ssd is password protected, you MUST have the password. Otherwise, you cannot access your data.
There is no unlock, or master password. If you do not have the password, you should properly dispose the SSD.
Doc
1342
I need this SSD hard drive with the same specifications of the photo, do you have it?
AlHill
This is a support forum for Intel hardware, not a supply or sales site.
Doc
1342
Yes, I know, I'm the end user. I just need a picture of the hard drive, I can only look for technical support from the official
AlHill
I am confused. You provided a photo of the SSD. You want another photo?
Doc
1342
yes, ​I need another hard drive photo of the same model to make a comparison. I need to see the hard drive circuit board.
AlHill
One of the Intel support engineers will assist you. There is no photo library available here to help you.
Doc
1342
How should I contact the enginee
AlHill
Just be patient. They will respond on this thread.
Doc
1342
JosafathB_Intel
1342
I see, thank you for your advice.
DO000
I had same Intel SSDSCKKF512H6 M.2 series SSD. Failed, unrecoverable. Intel makes bad SSD, else I happen to always get faulty Intel SSD that fails unexpectedly. Last year, a different laptop of mine with Intel SSD 520 series, after 3 years of use unexpectedly fails.
