cancel
Showing results for
Search instead for
Did you mean:
530 Raid 0 - 180gb
MMiro4
New Contributor
I'm looking to do the firmware update for my SSDs, but I'm not sure how it will work. Am I okay to update one at a time? Or is there an option to update both at the same time?
Current: DC12
Update to DC32_180
Thank you
2 REPLIES 2
Jose_H_Intel1
Valued Contributor II
Hello burncycle, let me just verify if it is possible to update the firmware while the drives are in RAID .
Jose_H_Intel1
We have confirmed that you should not need to break the RAID to do a firmware update unless the drives are attached to an add-in RAID controller. You can update the firmware while they are attached to the normal motherboard SATA ports.
