Community
cancel
Showing results for
Search instead for
Did you mean:
GJohn2
530 SSD freezes & kills computer after a few minutes?
I have an Asus Q501LA notebook. It is running Windows 8 (not 8.1) 64bit, with all drivers and firmware current. I have installed an Intel 530 180gb SSD. I had problems with it a few weeks ago, where the computer would randomly freeze and die after maybe 5-10 minutes. Since I saw that there was a new firmware in the works, I took out the drive and waited.
Well, I just applied the new firmware that was released a few days ago, but it is still doing the same thing. Without warning or indication, the computer freezes up and dies. I get a BSOD, and it says CRITICAL_PROCESS_DIED (it very briefly blinks on screen, I think that is what it says though). The notebook then reboots, and usually the ssd isn't listed in the bios. It has to be the SSD at fault, because it works fine with the original hard drive. Windows' Event Log isn't giving me any hints at all, which leads me to believe that it is the SSD that is spontaneously dying, thus preventing Windows from writing any events to the log. All the SMART parameters are normal. This doesn't seem to be the same problem that others are experiencing, because I did get Windows installed on it. Can anyone recommend something so that I can diagnose the problem?
Edit: Talked to Asus tech support, and they said it was an incompatibility between the SSD and the notebook because the SSD operates at 6gb/s while the notebook can only handle 3gb/s. I don't believe this at all, backwards compatibility is built into the SATA specs.
Tags (1)
Jose_H_Intel1
I wonder if the issue occurs as soon as the system initiates or if it gives you some time to run the diagnostic tests with the https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 Intel® SSD Toolbox. You may also test the Intel® SSD in a different system if possible.
This could also be an operating system or driver issue; it is important to review if something else changed recently before the issue started to happen or if the issue occurs in safe mode.
http://windows.microsoft.com/en-us/windows-8/windows-startup-settings-including-safe-mode http://windows.microsoft.com/en-us/windows-8/windows-startup-settings-including-safe-mode
http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc http://windows.microsoft.com/en-us/windows-8/restore-refresh-reset-pc
GJohn2
I ran the diagnostics, and no issues were found on the SSD.
I wiped the SSD clear and re-installed Windows 8 from scratch several times yesterday. I have discovered that Windows 8 is now evidently stable. I guess new SSD firmware must have fixed the issue I had previously? Unfortunately, a new issue arises. If I attempt to upgrade to Windows 8.1, I will either get an error on install or it will install but then never actually boot into Windows ever again. Something is incompatible with Windows 8.1.
The error I'm getting is 0xC1900101 - 0x20017, which is a sign that a driver is not compatible with Win 8.1, according to MS: http://answers.microsoft.com/en-us/windows/forum/windows8_1-windows_install/error-0xc1900101-0x20017... Error 0xC1900101 - 0x20017 after reboot to install Windows 8.1 - Microsoft Community. I have used Windows Update to get as many things installed as possible, and I went to the manufacturer's webpage (including Intel) to find newer drivers if applicable. Everything is as up to date as possible.
When I attempt to install 8.1, it looks like the machine can't detect the SSD after rebooting. I can't find the drive listed in the bios. If I kill the computer for a cold boot, it appears again. If I have the original hard drive in the machine, there are no issues at all with Windows 8.1. It is only when the SSD is installed on the system that it does this.
Considering that the problem only appears when this SSD is installed, and the problem indicates that there is a driver incompatible with Win 8.1, is there any way the SATA controller driver is at fault here?
Jose_H_Intel1
I do not think so; the drive does not appear in BIOS after a system restart.
I believe the best chance is to update the BIOS.
Jose_H_Intel1
I managed to get the information you provided via PM.
I have sent you a new PM.
Thanks!
cgawa
I'm having the exact same issue. Is there a fix for this? I am very frustrated with my 530 and the random freezing
Jose_H_Intel1
So, your issue occurs when you are trying to upgrade from Windows* 8 to 8.1?
Can you provide some information about your system, such as brand and model?
cgawa
No. My issue is just In windows 7 64 bit. I can do a fresh install. Runs for a bit then I get a random freeze along with the BSOD. If I hit reset, bios won't recognize the hard drive. When I power down and reload windows it recognizes the ssd again like mentioned by other users. Once back in windows it will randomly freeze weather I'm using the Internet or browsing files. It shouldn't freeze like this. My other hard drives don't do this on my system
My custom build specs:
GA-Z68AP-D3 motherboard with updated bios
I2500k
Gtx 560 ti
Intel 530 ssd
Jose_H_Intel1
It is not the same issue as the OP had.
Did you update the Intel® SSD to the https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18363 latest firmware?
Are you using Intel® Rapid Storage Technology or the Microsoft inbox driver for the SATA controller? Can you try the one you are not using?
Please run the Intel® SSD Toolbox diagnostic scan.
cgawa
In my device manager it says my sata achi controller is running driver version 9.2.0.1011
This appears to be the latest version for my intel 6 motherboard
I have also tried the Intel toolbox driver and software. I've ran the diagnostics tool and there are no errors with the drive. I still have freezing. Even after running the optimizer i'm still having freezing. I've also removed the Intel toolbox and I'm still having freeze issues.
What exact version of RST should I be running? Are all versions compatible with my intel 6 motherboard?
Jose_H_Intel1
The last version of Intel® Rapid Storage Technology your system supports is 12.9.
Do you have the chance to test the Intel® SSD in a different system?
cgawa
I tried 12.9 of rapid storage and it still freezes. Unfortunately I don't have access to another computer to try it on. I have another ssd from another manufacturer that I run and I have no issues with it.
Is there anything else we can try or is my intel ssd drive faulty?
Jose_H_Intel1
You may try a clean operating system installation just to discard software corruption issues.
It is difficult to determine if it is a compatibility issue without testing the drive in a different computer but you may replace it with your local http://www.intel.com/p/en_US/support/contactsupport Intel support if you believe it is bad.
cgawa
I've tried cleaning the operating system 4 times and the same thing happens. I've tried old drivers, new drivers, even no drivers at all. Safe to say I've done everything possible and everything you've recommended.
I bought the intel ssd in another city far from where I live. How do I go about warranty?
Jose_H_Intel1
Please contact the Intel support center so they can inform you of the available warranty options.
