Community
cancel
Showing results for
Search instead for
Did you mean:
BPett
530 fails full diagnostic test
Hi i have 2 530 240 GB SSD's and they both are failing the full diagnostic test at around 78% completion. They are both brand new and have the latest firmware.
Basic hardware:
Intel Core i7-4770
Gigabyte GA-Z87X-UD5H
Corsair CML16GX3M4A1600C9
windows 7
I have ran memtest86 on my ram for around 10 passes and 6 passes on each stick individually, so now im wondering if its just an issue with toolbox.
Jose_H_Intel1
Hi Brice, I am sorry to know about your issue.
I see that your motherboard has two SATA controllers (see Storage Interfaces in the http://www.gigabyte.com/products/product-page.aspx?pid=4483# sp specifications).
I wonder if it is possible to test the drives in the Intel® SATA controller (Intel® Z87 Express Chipset).
I also sent you a PM.
BPett
these drives have been in slot 0 and 1 of the Intel controller since i installed them and the story holds true for both drives, test fails at around 76-78% completion on the data integrity scan.
My BIOS is the latest version as well.
Jose_H_Intel1
Are the drives setup in a RAID volume?
Are you using Intel® Rapid Storage Technology driver or Microsoft's counterpart? Using the other one may help.
Does it make a difference if you disable the Marvell controller?
BPett
no, no raid. removed IRST and all is well. Thank you for your help. I actually think windows booted faster without IRST but i may be delusional.
