Community
cancel
Showing results for
Search instead for
Did you mean:
CHugo2
530 series 120 gb ssd in MacBook late 2009.
Hi. Thinking about buying the Intel 530 series 120 gb ssd. Is it possible to run on my computer? I have a MacBook white late 2009.
ASouz7
Hello ChristiniaH
Intel(R) SSDs are designed to work well with most brands with no issue at all. However, we strongly recommend that you contact Apple* prior to purchasing the drive so they will provide you the most accurate information about system compatibility.
ASouz7
Hello ChristianH
We also have had reports of issues with older Mac Books with our 530's. We have investigated and found that some of these older systems don't always support the newer power savings feature in the 530 Series. If you have a 2009 or earlier system, it may not work.
