I have a Intel SSD 535 - SSDSC2BW480H6. It has begun to fail on my motherboard, started happening about 4 months ago. It worked fine for about a year and a half but about 4 months ago it started to not show up on my motherboard. Initially I had to install a new ssd hard drive, however it showed up on the bios screen one time. Now it goes off and on randomly. I have to do several reboots in order for it to come back on line. I did run the Intel Solid State Drive Tool box for a full diagnostic Scan but nothing failed. Just started a second scan right now. Checked for a new firmware but no update showed, so now I have the following questions:
Any help would be appreciated.
Hi eforonda,
Thank you for posting in the Intel® communities.
The issue you are describing has similar symptoms of an issue reported with the DevSleep feature of some SSDs (including the Intel® SSD 535 Series). The DevSleep feature allows the device to go into a low power "device sleep" state, but sometimes the motherboard does not signal to wake up the SSD back.
It may be possible to solve the issue without the need of an RMA, so let's first try the following in order to recover the drive.
The first recommendation is to update the BIOS version of your motherboard to the latest one, as it may not support the DevSleep feature in the current BIOS version. However, if there are no updates available for the BIOS, we can try to disable the DevSleep feature on the SSD by following the steps below:
Note: If the PC doesn't boot from the USB flash drive or gives you an error, please go to the BIOS again and change the boot mode to Legacy only. The try again these steps.
Please try this process and let me know how it goes. If you have any questions, don't hesitate to ask.
Have a nice day.
Diego V.
Hello Diego,
Thank you for the information, I have updated the bios. However, I am not sure if it the new version supports Devsleep, there is no mention of the new bios supporting Devsleep in the release notes. I did try updating the firmware on the SSD, and have been unsuccessful in getting to the update firmware tool. I boot to the usb stick however the boot stops with the following error:
couldn't find an input interrupt endpoint giving up. unable to connecto X server: Connection refused server error.
I did the legacy only mode but I get the same error. The motherboard I am using is a Gigabyte g1 gaming ga-z170mx-gaming 5 firmware/bios version: F22f. In case you can look into the settings I need to change.
How large does the USB stick have to be? Any guidance would be greatly appreciated.
Also is there maybe another reason for the issue given that the ssd never had an issue for about a year and a half?
Heya, I have done this with 1GB NanoFlash. Also Rfus ask me how to write ISO, I use ISO recommended mode, but you can try other "DD" mode. With this FW will be RG2P /sounds, like performance I hope/ Also with that USB can switch between 2 versions of firmware.
Hi eforonda,
I've just tried to boot from the USB flash drive to see if I got the same message as you did, but it worked fine for me.
I used a 16GB USB flash drive. I formatted it before creating the bootable unit. Regarding to the BIOS settings, I only had to change in the Boot menu the option of booting from storage devices to "Legacy Only", and set the USB flash drive as the first drive to boot from and everything worked fine.
Could you please try to create the bootable unit once again and try it one more time? This is how I created the bootable unit:
Please try it again and let me know if you get the same error message again.
Regarding to the issue itself, it usually start happening after some time of using the drive which is the same scenario that you described. That's why it seems to be related to the DevSleep feature. Although there is also the chance that the drive has another issue. We can check the health of the drive by checking the SMART attributes. In order to get this information, please run the Intel® SSD Toolbox and get the SMART attributes report of the drive. You can download the Intel® SSD Toolbox from this site: https://downloadcenter.intel.com/download/27656/Intel-Solid-State-Drive-Toolbox https://downloadcenter.intel.com/download/27656/Intel-Solid-State-Drive-Toolbox
Have a nice day.
Diego V.
I have yet to complete the steps you have described but I do think the firmware update has resolved this issue. I have had my computer on for the past couple of days with out having the hard drive disconnect. I will see how it ends up by end of week.
Thanks for all the help hopefully this issue will not creep up on me again.
Hi eforonda,
That's great!
Let's see how the drive behaves by the end of week.
Diego V.
So unfortunately this friday the drive disappeared again. I followed the steps you list out above exactly.
I set the Storage Boot Option Control: Legacy
I downloaded the RUFU Portable tool, and the *.iso image. I ran the program as you showed in your previous post however I get the following error:
Fatal server error: (EE) no screens found(EE)
(EE) Server terminated with error (1)
Not sure what I am doing wrong here, since you were able to do this successfully. Any advice?
Hi eforonda,
I haven't seen that error message before, but according to what I have searched about it, the error message is related to the video/graphics card your system has. Do you have an external video card, or you are using the one embedded in the motherboard? I'm not sure about this, but this could be fixed by disabling the external video card and using the embedded one. Although, it would be easier and less strenuous if you have access to another computer where you can test the ISO image and see if you get the same result.
Don't worry if you don't have another computer. I just want to explain you what seems to be the reason of that error message and how we could try to solve it or at least try a workaround (another computer).
I'll keep investigating about it and see what other options we have.
Let me know if it's possible to test it in another computer.
Have a nice day.
Diego V.
Hi eforonda,
Have you had any chance to follow my suggestion above or to test it in another computer?
Diego V.
Hello Diego,
I finally had sometime to test it on another computer and on this computer I have a hang on boot, the usb stick does not even get past the first boot screen it only has a prompt something like this: boot: _ with the cursor and on the top line: looking like this SYSLINUX 6.01 EBB...so on and so on. At this point I would like to get my defective product replaced. It is a defective product because it is not working at this point, is well within the time of the warranty, and I have grown tired of all these steps I am not here to fix the mistakes on Intel's part which led to my drive being defective. I have spent enough time and energy with all the steps you have listed, and obviously the steps are not correct either that or the image is not suitable for all the setups. I have jump through enough hoops for you to send me a replacement drive with out me having to do anything else. So at this point I would like a replacement drive, I purchased a Intel drive with the hopes that I wouldn't have to deal with an issue like this. I would like you to PM and we can work out the details of you sending me a replacement drive. I have done enough of setting up and tearing down this will be the last Intel product I will ever purchase just due to this experience.
Hi eforonda,
I completely understand you. We'll proceed with the replacement process, however the troubleshooting process that we went through is necessary as it can tell us what the root cause of the issue could be, or it could resolve the issue avoiding additional processes like the replacement one. Of course, there are scenarios like this one, where the issue is not fixed after the troubleshooting process is done.
Anyhow, as I mentioned, we'll proceed with the replacement process so you don't have to be worried about it. I understand that the process sometimes becomes exhaustive and long, but we always try to make it as easy as possible for the users.
I'll send you a private message with additional information so that we can start with the replacement process. I apologize for any inconveniences this may have caused to you.
Have a nice day.
Diego V.
