Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
540s 240Gb ssd issue
zszab1
Intel 540s 240Gb. M.2 sata
The bios has not been seen the SSD since the firmware update
Linux Mint 18.1 + processor driver integrated live: see, write and read the SSD
Windows 10 only writes but does not read.
Is it possible to fix it
Thank you for your ansver
Community Manager
Hi zolinak75,
Thank you for contacting our support community.
We understand your situation regarding the Intel® SSD 540s Series.
In order to better address your situation, could you please confirm the following information:
*Are you using the SSD as a boot drive or as a storage device?
*Have you tested the SSD in a different M.2 port?
*Have you tried to perform a secure erase to the SSD?
*How did you determinate that you can not read and only can write to the SSD? Do you get an error message? If so, please attach the screenshots of it.
We look forward to hearing back from you.
Junior M.
zszab1
Dear Junior!
Thank you for your quick answer!
* I would like to use it as a boot drive, but if it works as a storage drive, I could use it now. It is unusable at this time.
* 1 M.2 port on the machine. I have no other machine with a M.2 slot.
* Safe deletion? I do not know what is it. I just formatted in my linux system. Windows 10 indicates an error when I try to format it.
https://drive.google.com/open?id=16UAqmEWtmnrhccCYEIJbGOo5oVbnaI9i https://drive.google.com/open?id=16UAqmEWtmnrhccCYEIJbGOo5oVbnaI9i
* Linux Mint 18.3 + Apollo-lake isorespin.sh modified live system, writes and reads it as well. I measured the speed with gnome-disks:
https://drive.google.com/open?id=1c7vGzUU1yq35G-gdbc0Tlif_8rD9dqqE https://drive.google.com/open?id=1c7vGzUU1yq35G-gdbc0Tlif_8rD9dqqE
I measured the speed with Windows 10 home system, CrystalDiscMark.
https://drive.google.com/open?id=1Lt2p1j6NszQGhLZ9WXkQhHVgThqarOWG https://drive.google.com/open?id=1Lt2p1j6NszQGhLZ9WXkQhHVgThqarOWG
Error messages:
https://drive.google.com/open?id=16j1lz482rAiujQu3A-AijfL7XWFrZE8W https://drive.google.com/open?id=16j1lz482rAiujQu3A-AijfL7XWFrZE8W
You can find all the information here:
https://drive.google.com/open?id=1M7T8FIeAgkQrvmhdp1XI9P2fqvI3uIQl https://drive.google.com/open?id=1M7T8FIeAgkQrvmhdp1XI9P2fqvI3uIQl
**The seller is perfect. This proves: intel.csv in the attachment. Does this confirm the perfect operation?
Best regards
Community Manager
Hi zolinak75,
Thank you for the reply.
Based on the information and the screenshots attached, we recommend you to contact your https://www.intel.com/content/www/us/en/support/contact-support.html# @3 local support team for further assistance.
Junior M.
