cancel
Showing results for
Search instead for
Did you mean:
540s 'SError: { UnrecFIS }' on linux boot irregulary
NZeju
New Contributor
I'am trying to understand the meaning and severe of a totally irregular appearing error during boot according to one of the SSDs connected to my NUC5I5RYH:
New SSD M.2 240GB INTEL SSDSCKKW24 (Modell: 540s), Firmware Version: LSF036C, checked without any errors with Intels SSD Tool (with W10), SMART values unremarkable.
SATA controller: Intel Corporation Wildcat Point-LP SATA Controller [AHCI Mode] (rev 03) (prog-if 01 [AHCI 1.0])
CPU: Intel(R) Core(TM) i5-5250U (Broadwell-U)
OS: ArchLinux, 4.8.12-3 x86_64 GNU/Linux
I testet reboot, boot after shutdown and boot after shutdown with power unplugged.
On every ca. fifth to tenth boot I get:
[code]
ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
ata4.00: ATA-10: INTEL SSDSCKKW240H6, LSF036C, max UDMA/133
ata4.00: 468862128 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
ata4.00: READ LOG DMA EXT failed, trying unqueued
ata4.00: failed to get Identify Device Data, Emask 0x40
ata4.00: configured for UDMA/133
ata4: exception Emask 0x2 SAct 0x0 SErr 0x2000000 action 0x6 frozen t4
ata4: irq_stat 0x00000011, unknown FIS 00478027 a0000830 00000000 08000001
ata4: SError: { UnrecFIS }
ata4: hard resetting link
[/code]
Perhaps related to former June 2016 031C firmware release which provided the following changes:
* Corrected errant FIS causing BSOD when Write Cache disabled
21 REPLIES 21
Esteemed Contributor III
Hello Jfp42,
Thanks for reporting the situation as well.
Could you and nadotu please share your system details as specific as possible?
Computer model/brand, hardware included, software installed, etc.
We will be waiting for your response, in the meantime we continue with our research.
NC
JPiru
New Contributor
Hi small correction, this server is actually running up to date Centos 7. (sorry, new year's brain fart)
CentOS Linux release 7.3.1611 (Core)
Linux server1 3.10.0-514.2.2.el7.x86_64 # 1 SMP Tue Dec 6 23:06:41 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
Base Board Information
Manufacturer: ASRock
Product Name: 970 Pro3 R2.0
Version:
BIOS Information
Vendor: American Megatrends Inc.
Version: P2.40
Release Date: 08/05/2015
Memory Device
Array Handle: 0x000E
Error Information Handle: Not Provided
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A1_DIMM0
Bank Locator: A1_BANK0
Type: DDR3
Type Detail: Synchronous Unbuffered (Unregistered)
Speed: 1600 MHz
Manufacturer: Kingston
Asset Tag: A1_AssetTagNum0
Part Number: 99U5403-160.A00LF
Rank: 2
Configured Clock Speed: 800 MHz
Memory Device
Data Width: 64 bits
Form Factor: DIMM
Set: None
Locator: A1_DIMM1
Bank Locator: A1_BANK1
Type: DDR3
Speed: 1600 MHz
Asset Tag: A1_AssetTagNum1
Rank: 2
vendor_id : AuthenticAMD
cpu family : 21
model : 2
model name : AMD FX(tm)-8320 Eight-Core Processor
stepping : 0
microcode : 0x600084f
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD9x0/RX980 Host Bridge (rev 02)
00:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GFX port 0)
00:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] RD890/RD9x0/RX980 PCI to PCI bridge (PCI Express GPP Port 4)
00:11.0 SATA controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 SATA Controller [AHCI mode] (rev 40)
00:12.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:12.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:13.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:13.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 SMBus Controller (rev 42)
00:14.1 IDE interface: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 IDE Controller (rev 40)
00:14.2 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 Azalia (Intel HDA) (rev 40)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 LPC host controller (rev 40)
00:14.4 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SBx00 PCI to PCI Bridge (rev 40)
00:14.5 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI2 Controller
00:15.0 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB700/SB800/SB900 PCI to PCI bridge (PCIE port 0)
00:15.3 PCI bridge: Advanced Micro Devices, Inc. [AMD/ATI] SB900 PCI to PCI bridge (PCIE port 3)
00:16.0 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB OHCI0 Controller
00:16.2 USB controller: Advanced Micro Devices, Inc. [AMD/ATI] SB7x0/SB8x0/SB9x0 USB EHCI Controller
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 15h Processor Function 5
01:00.0 VGA compatible controller: NVIDIA Corporation GT218 [GeForce 210] (rev a2)
01:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
02:00.0 USB controller: Etron Technology, Inc. EJ188/EJ198 USB 3.0 Host Controller
03:05.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8169 PCI Gigabit Ethernet Controller (rev 10)
05:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 06)
[ 1.343615] ahci 0000:00:11.0: version 3.0
[ 1.343781] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 4 ports 6 Gbps 0xf impl SATA mode
[ 1.343784] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part
[ 1.344317] scsi host2: ahci
[ 1.344441] scsi host3: ahci
[ 1.344888] scsi host4: ahci
[ 1.344998] scsi host5: ahci
[ 1.345036] ata3: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b100 irq 19
[ 1.345039] ata4: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b180 irq 19
[ 1.345041] ata5: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b200 irq 19
[ 1.345044] ata6: SATA max UDMA/133 abar m1024@0xfe30b000 port 0xfe30b280 irq 19
[ 1.649639] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.649694] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.804638] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.804670] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 1.805216] ata5.00: ATA-10: WDC WD10EZEX-00MFCA0, 01.01A01, max UDMA/133
[ 1.805219] ata5.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.805488] ata3.00: ATA-10: INTEL SSDSC2KW120H6, LSF036C, max UDMA/133
[ 1.805491] ata3.00: 234441648 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 1.805943] ata5.00: configured for UDMA/133
[ 1.805957] ata3.00: READ LOG DMA EXT failed, trying unqueued
[ 1.805959] ata3.00: failed to get Identify Device Data, Emask 0x40
[ 1.805962] ata3.00: configured for UDMA/133
[ 1.805967] ata3: exception Emask 0x2 SAct 0x0 SErr 0x2000000 action 0x6 frozen t4
[ 1.806009] ata3: irq_stat 0x00000011, unknown FIS 00478027 a0000830 00000000 08000001
[ 1.806050] ata3: SError: { UnrecFIS }
[ 1.806088] ata3: hard resetting link
[ 1.871679] tsc: Refined TSC clocksource calibration: 3492.378 MHz
[ 1.871755] Switched to clocksource tsc
[ 2.265604] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[ 2.266981] ata3.00: configured for UDMA/133
[ 2.266985] ata3: EH complete
[ 2.267102] scsi 2:0:0:0: Direct-Access ATA INTEL SSDSC2KW12 036C PQ: 0 ANSI: 5
[ 2.277991] scsi 4:0:0:0: Direct-Ac...
Hello all,
We believe we have found the root cause and potential fix. We are currently implementing and validating this fix. no ETA on schedule for a release as of yet.We will keep you all posted here.Regards,NC
Hello all,
The latest firmware update contains the fix for this situation, please https://downloadcenter.intel.com/download/26491/Intel-SSD-Firmware-Update-Tool?product=80097 download it from this link.In case the ISO is not booting up normally, please try changing the BIOS settings to legacy boot mode, so it can properly boot.Regards,Nestor C
aburn7
New Contributor
I have an Intel 540s running on a Thinkpad P50 and am experiencing the same errors with the latest firmware (both computer and ssd as of writing this). This is on Linux 4.11. No such errors occur with a Samsung 850 Evo Pro or Samsung 950 Evo or Samsung 960 Evo on this computer.
[8.789556] blk_update_request: I/O error, dev sda, sector 344783176[8.789596] ata1: EH complete[8.848803] ata1.00: exception Emask 0x0 SAct 0x3e80000 SErr 0x0 action 0x0[8.848806] ata1.00: irq_stat 0x40000008[8.848808] ata1.00: failed command: READ FPDMA QUEUED[8.848810] ata1.00: cmd 60/08:98:10:fa:8c/00:00:14:00:00/40 tag 19 ncq dma 4096 in res 41/40:08:10:fa:8c/00:00:14:00:00/40 Emask 0x409 (media error) [8.848812] ata1.00: status: { DRDY ERR }[
8.848813] ata1.00: error: { UNC }
