Community
cancel
Showing results for
Search instead for
Did you mean:
PStep4
6 x SSD's in Raid "0" and "Trim" in Win 7
<!--[if gte mso 9]> Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--><!--[if gte mso 9]> <![endif]--><!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} a:link, span.MsoHyperlink {color:blue; text-decoration:underline; text-underline:single;} a:visited, span.MsoHyperlinkFollowed {color:purple; text-decoration:underline; text-underline:single;} @page Section1 {size:595.3pt 841.9pt; margin:1.0cm 1.0cm 1.0cm 1.0cm; mso-header-margin:35.45pt; mso-footer-margin:35.45pt; mso-paper-source:0;} div.Section1 {page:Section1;} --><!--[if gte mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:# 0400; mso-fareast-language:# 0400; mso-bidi-language:# 0400;} <![endif]-->
I am trying to find out if there are any plans Intel Raid drivers to provide support for SSD arrays with respect to "Trim" function. "Trim" provides a similar function to defragging a HDD. "Trim" is built into Win 7, but only supports single drives - not Raid. I have 6 X Super Talent SSD's in Raid, see below pic.
http://s462.photobucket.com/albums/qq348/sgtreasure/?action=view&current=ssdidsinv.jpg http://s462.photobucket.com/albums/qq348/sgtreasure/?action=view&current=ssdidsinv.jpg
I suppose the question here is "Do Raid controllers need to be modified in any way so that "Trim" can work on SSD's in a Raid 0 array"
Below are my attempts to find out about being able to beef up the performance of SSD's, similar to how defragging would.
http://www.supertalent.com/home/forum/viewtopic.php?f=4&t=105 http://www.supertalent.com/home/forum/viewtopic.php?f=4&t=105
http://blogs.msdn.com/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx http://blogs.msdn.com/e7/archive/2009/05/05/support-and-q-a-for-solid-state-drives-and.aspx
A Post in the MSDN" forum. "Typically the disks behind a RAID controller are managed by the RAID controller and presented to the operating system as one or more units (disks) of storage space. If the RAID controller reports the rotational speed as zero for the units of storage (disks) that it presents to Windows 7 then it will treat that unit of storage as an SSD"
Community Manager
Hi Treasure,
cannot open photobucket?
thanks
Jeff
PStep4
Hi Jeff,
Right click on link and select "open in new window", or copy and paste into address bar. i dont know why it doesnt work like other links.
Community Manager
The current Intel ssd's will need a firmware update and the controllers will also need to be updated for native TRIM support to work. My guess is the new Intel ssd's will have TRIM, in which case it is likely that the generation one drives and controllers will be updated as well.
If your ST drives are indilinx based you can use the stand alone TRIM tool they provide as an interim measure. I think it is possible to use the indilinx TRIM tool with a raid set up if you set the bios out of raid first, run TRIM and then switch back to raid.....but I might me wrong there. ST should be able to advice.
Community Manager
ok, works. Thanks
Jeff
