cancel
Showing results for
Search instead for
Did you mean:
60gb x25m g2 with read/write 4k of 10-13 mb/s?! help!
Esteemed Contributor III
hey everyone. i did a fresh 7 install, in AHCI mode, did all the SSD tweaks, etc etc. drive is brand new.
i get (sry no pic)
Seq: R:251 W:1044K: R:13 W:124K64: R:143 W:65Time: 0.113 / 0.185everything is great and i did everything listed by intel and guides, etc. why is the 4k so low? faulty drive?anyone had this?thanks
everything is AWESOME. but the 4k is damn terrible. what could be doing this?other than my 4k these numbers are some of the best i have seen
8 REPLIES 8
More than likely there is nothing you can do, apart from hassle ASUS and look for driver/ bios/ firmware updates. Changing the block size will not help. Whilst it is no doubt annoying that your ssd is not working optimally the difference is not something you will really notice outside of a benchmark.
thanks redux. i booted in safe mode and ran it again and the 4k went twice as good. 20/50
so it must be a driver thing
at least my ssd is working ok
what if the allocation units are offset. could this cause this latency?
if so and in general anyway, how do i completley wipe the ssd + recovery partition in order to set the alignment perfect on a fresh install. last fresh install i did the alignment is a liiiitle off.
thanks
Just a quick sanity check:
Intel does not make a 60GB X-25M G2. I assume you meant to type 80GB -- correct?
