Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
7 Series SSD RAID 0 Trim
I have a question about a RAID 0 Array with two SSD drives. I have installed the RST program, version 11.6.0.1030. I am curious if there is a way to verify if TRIM is enabled and functioning. I checked Windows 7 Command Prompt, but I don't believe these are one in the same.
Tags (2)
Jose_H_Intel1
Hello Corbin,
The following article may help you:
How to check if TRIM is enabled?
http://www.intel.com/support/ssdc/hpssd/sb/cs-032318.htm http://www.intel.com/support/ssdc/hpssd/sb/cs-032318.htm
