cancel
Showing results for
Search instead for
Did you mean:
7600P不能制作为启动盘,另外启动时显示扫描和修复
常jian
New Contributor II
是7600p 1t的​固态盘,能在BIOS里面看到,我将它做为启动盘安装Win10,整个安装过程无报错。但是启动时说是“No boot device”,这时在BIOS中是能看到7600p的。
我也试过拔掉原来固态,单独仅7600p安装Win10,还是不能启动。比较奇怪的是,我用原来的固态硬盘引导启动后,在资源管理器里面看7600p,奇怪的竟是空白盘,我刚刚还新安装了Win10过程的,没有出错信息。
另外,我现在将7600P做为数据盘,用原来的固态盘启动,就是每次启动时都显示“正在扫描和修复驱动器(\\?\Volume{84910fa4-011c-409a-8ec7-1527c9cc628e}):已完成100%”。
7600p固态已经升级是 L12C。
请师傅指导,这两个问题能解决吗?
1 ACCEPTED SOLUTION
LeonWaksman
Contributor II
  1. Remove all other drives from your computer. Leave only the 7600p installed.
  2. Boot into BIOS and verify that the M.2 slot is enabled and the 7600p is recognized.
  3. UEFI Boot in BIOS should be enabled. The 7600p is an NVMe drive that's works with UEFI boot.
  4. Please prepare your installation media (you need 8GB – 32GB USB stick), using Microsoft Media Creation Tool.
  5. With the installation media inserted into rear USB slot, power ON your computer.
  6. Your computer should boot from the installation USB .
  7. Follow this tutorial to continue with installation.
  8. In para. 7 you may enter Product Key from the Microsoft Distribution you bought.
  9. Skip on para. 12 and continue in para. 13. Important, do not format drive where you want to install Windows, rather delete all existing partitions from this drive, till you see one unallocated space.
  10. Press Next and continue with the installation.
Leon
12 REPLIES 12
常jian
New Contributor II
现在是已经用原来的SK hynix启动系统,并安装了Intel SSD。我怀疑 Microsoft Storage Space Device不应该存在,已经将其卸载:
在intel ​ssd tools box 里面除了不能固件升级外,其他正常。
运行powershell​
LeonWaksman
Contributor II
  1. I can't translate what is written on the image. However, I can guess that Disk 0 is the SATA drive, while the Disk 1 is the 7600p. It's looks that all space on this drive (953GB) is unallocated = free? Did you installed Windows as I suggested in my post?
  2. Please run again diskpart in Admin PowerShell. Next run list disk and then select disk 1 (I'm assuming tat Disk 1 is the 7600p drive). Now run detail disk .
Leon
常jian
New Contributor II
Thank you, my nice friend!
我做了检查,情况如下:
1、确实如你所说,Disk0 是 SATA,Disk1是7600P。看见未分配可用空间是953G,可能是我刚将Microsoft Storage Space删除,所以有953G自由空间。
我按你说明的步骤制作过7600P的启动盘,包括拔掉SATA硬盘仅留7600P安装WIn10,但是还是启动不了,说找不到可启动设备。
我猜想原因可能是DELL 7050主板不支持单独Nvme硬盘启动,不是7600P的问题。
我现在也没有再要求7600P做启动盘的想法了,太麻烦了,算了。原来计算机启动时总是出现“扫描和修复”的提示,现在已经没有了,我很满足了。
2、截图
感谢您一直热心解答我的问题,谢谢您。
