Community
cancel
Showing results for
Search instead for
Did you mean:
常jian
7600P不能制作为启动盘,另外启动时显示扫描和修复
Jump to solution
是7600p 1t的​固态盘,能在BIOS里面看到,我将它做为启动盘安装Win10,整个安装过程无报错。但是启动时说是“No boot device”,这时在BIOS中是能看到7600p的。
我也试过拔掉原来固态,单独仅7600p安装Win10,还是不能启动。比较奇怪的是,我用原来的固态硬盘引导启动后,在资源管理器里面看7600p,奇怪的竟是空白盘,我刚刚还新安装了Win10过程的,没有出错信息。
另外,我现在将7600P做为数据盘,用原来的固态盘启动,就是每次启动时都显示“正在扫描和修复驱动器(\\?\Volume{84910fa4-011c-409a-8ec7-1527c9cc628e}):已完成100%”。
7600p固态已经升级是 L12C。
请师傅指导,这两个问题能解决吗?
LeonWaksman
  1. Remove all other drives from your computer. Leave only the 7600p installed.
  2. Boot into BIOS and verify that the M.2 slot is enabled and the 7600p is recognized.
  3. UEFI Boot in BIOS should be enabled. The 7600p is an NVMe drive that's works with UEFI boot.
  4. Please prepare your installation media (you need 8GB – 32GB USB stick), using Microsoft Media Creation Tool.
  5. With the installation media inserted into rear USB slot, power ON your computer.
  6. Your computer should boot from the installation USB .
  7. Follow this tutorial to continue with installation.
  8. In para. 7 you may enter Product Key from the Microsoft Distribution you bought.
  9. Skip on para. 12 and continue in para. 13. Important, do not format drive where you want to install Windows, rather delete all existing partitions from this drive, till you see one unallocated space.
  10. Press Next and continue with the installation.
Leon
LeonWaksman
Leon
常jian
谢谢。​
但是我已这样做过多次,过程都是安装成功。但是,安装结束后用固态盘启动时,就是只显示dell圆圈标识没到windows4方块标识时,屏幕说 No boot device 。
然后,我将另一块原来的 SSD装上,启动原来的Win10,在资源管理器里面看刚装了win10但不能启动的D盘,竟然没有任何内容,不知道是什么原因。
我从网上搜索,说是固态盘有掉电的说法,是不是可以在win系统、或者固态盘参数里改变哪个设置?有没有这方面的可能?
LeonWaksman
  1. What is P/N of the original SSD?
  2. Is the UEFI boot enabled in BIOS?
  3. Is the 7600p SSD installed in M.2 PCIe 3.1 x4 slot ?
  4. Can you see the 7200p in BIOS?
Leon
常jian
答:
1、再等两天我拆开机箱拍张照片,上面有P/N;
2、是UEFI方式;
3、主板上只有一个M.2接口,在原装SSD下面,我就插在那里;
4、在BIOS启动菜单能看见7600P,因为我反复装过系统多次,见过有UEFI方式的,也见过有BOOT manage方式的。
LeonWaksman
  1. The translation is inaccurate. However, I can understand the following:
  • UEFI boot in BIOS is enabled
  • The 7600p is installed in the same M.2 slot where the old SSD was installed
  • The 7600p is recognized in BIOS - you can see it in BIOS Boot screen. I assume that you can see it also in Device and PCIe screen.
2. If I correctly understand your post, please follow exactly my instruction and you will have bootable SSD. Install Windows with USB prepared with Microsoft Media Creation. Tool. Do not use installation media you have bought. Delete all existing partition instead of formatting drive.
Leon
常jian
谢谢你, You are very nice国际友人。
我没用其它硬盘,仅用​一块SSD安装Win10,但是这块SSD仍然不能启动。打开了UEFI,BIOS中也能看见SSD,但就是启动不成功。
虽然这次重装不能将SSD变成启动盘,但是还是有收获:我继续加装回原来硬盘,这次能在原来Win10里看见Intel SSD了,在系统启动时也不每次都显示“正在扫描和修复驱动器”了。
常jian
刚才内容显示出来,漏掉几张说明情况的图片,补充在下面:
常jian
Intel SSD 不能作为启动盘,我现在认为可能是DELL 主板不支持的原因,虽然我已经升级到最新的版本: 1.12.1。
我另外有对这个SSD疑惑的地方:
1、为什么标签是7600P,但是toolbox显示是760p
2、固件版本是L2C,不是查询出的最新版本004P或者004C,且不能升级固件
3、运行诊断扫描时显示:“所选 Intel SSD 没有分区。此功能需要分区才能运行。单击“帮助”了解更多信息。”
4、AS SSD Benchmark 显示如下
5、我装上原来的硬盘SK hynix 固态硬盘,在win10系统中设备管理器显示:
6、Intel SSD 近照:
LeonWaksman
  1. I'm not suspecting that this isn't 7600p drive, since in Windows Device Manager the P/N is correct for 7600p and not 760p.
  2. I don't know how you computer BIOS is organized. Since you this 7600SSD is recognized i don't see any reason that it can't be bootable.
  3. However, for UEFI boot (this is requirement for NVMe drive), the partition of this drive have to be GPT type (rather than MBR). The Windows should be installed while UEFI boot is enabled, following instruction I've given above.
  4. While you are booted in Windows (with the old SATA drive and the 7600p installed in M.2 slot), please open Windows PowerShell(Admin) and run the following commands (click enter after each command):
diskpart
list disk
5. Prepare image of PowerShell window showing your drives and attach to your post.
Leon
常jian
现在是已经用原来的SK hynix启动系统,并安装了Intel SSD。我怀疑 Microsoft Storage Space Device不应该存在,已经将其卸载:
在intel ​ssd tools box 里面除了不能固件升级外,其他正常。
运行powershell​
LeonWaksman
  1. I can't translate what is written on the image. However, I can guess that Disk 0 is the SATA drive, while the Disk 1 is the 7600p. It's looks that all space on this drive (953GB) is unallocated = free? Did you installed Windows as I suggested in my post?
  2. Please run again diskpart in Admin PowerShell. Next run list disk and then select disk 1 (I'm assuming tat Disk 1 is the 7600p drive). Now run detail disk .
Leon
常jian
Thank you, my nice friend!
我做了检查,情况如下:
1、确实如你所说,Disk0 是 SATA,Disk1是7600P。看见未分配可用空间是953G,可能是我刚将Microsoft Storage Space删除,所以有953G自由空间。
我按你说明的步骤制作过7600P的启动盘,包括拔掉SATA硬盘仅留7600P安装WIn10,但是还是启动不了,说找不到可启动设备。
我猜想原因可能是DELL 7050主板不支持单独Nvme硬盘启动,不是7600P的问题。
我现在也没有再要求7600P做启动盘的想法了,太麻烦了,算了。原来计算机启动时总是出现“扫描和修复”的提示,现在已经没有了,我很满足了。
2、截图
感谢您一直热心解答我的问题,谢谢您。
