Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
80Gb ssd is now onley 8Mb
Hello guys
I got a strange problem. Today i received my SSD and i wanted to instal W7 on it. First i could see the SSd in the bios but not in the windows screen where you can partition the disks.
No i got that problem solved. But the disk is onley 8Mb
My system specs
Asus Crosshair formula 2
AMD Phenom2 x940
if you need more info just ask and i will post it
Tags (1)
Community Manager
That certainly is a strange problem. Have you tried to format it in Windows 7 as a basic disk? And did you initialize the disk? Is the SSD shown as being online?
Seems like the disk is not formatted correctly.
Community Manager
i can see the disk in windows but i cant do much with it, i can onley format the 8Mb and make a partition on that piece of the disk
Community Manager
Have you used HDDErase? HDDErase can screw up your SSD with that 8MB issue. We can get into trying to fix it if you did mess up with HDDErase.
Community Manager
nope i didnt used annything yet. I ordered a new one today and i think its better to send this one back. unless i can get it to work again
Steve_Lionel
Black Belt Retired Employee
I have seen this problem reported with other disks, mainly SSDs. It appears to be a failure of the drive's controller. Get it replaced under warranty.
Community Manager
What firmware version is on the drive?
Community Manager
Apologies for the problems you are having with your X-25M.
If the problem continues, please RMA the drive for replacment.
FYI: "Intel BootLoader" and a drive size of 8MB typically means that the firmware cannot be found.
Community Manager
I ordered a new one installed it and it worked. so im gonna RMA the broken one:)
thx for the reply's
Community Manager
I have an Asus M2npv-vm motherboard running Windows XP Pro and I see exact same issues. The drive is an Kingston SSD 96 GB. I worked with Kingston and the RMA the first device. Without any explanation of what they did, they sent me a new drive. The new drive has the exact same problem I can only see 7.84 MB of the total 96 GB. Did you go with a different vendor than Kingston, such as the Kingston was not working and another vendor 's SSD worked?
Matt
Community Manager
Hi Matt, I have the same issue. Same motherboard as your Asus M2NPV-VM, with Kingston SSD 30G. The SSD works well in my notebook and install windows 7 without any problem. I wonder if the M2NPV-VM is too old to install an SSD.
